DSm415pf Error message 36851 network scanning using VISTA
Joshua Herrero
Re: DSm415pf Error message 36851 network scanning using VISTA
Some applications doesn't support twain drivers anymore but require drivers "wia" compatible drivers (windows image aquisition) - no chance with most ricohs. Be shure that you test the driver with a twain compatible software (like irfanview).
If SMB scan doesn't work you can use FTP as workaround for most MFPs.Comment
