C5502 memory device not found
  • mrfuser
    • 1622
    Re: C5502 memory device not found
    what size/type thumb drive?
    are you sure the port is active?
    can you post config page?
      • 37532
      Sounds like a problem with the default settings for scanning.
      • FrohnB
        • Jul 2017
        • 1919
        Try SP 5-801-009 to clear scanner app memory.
        Omertà
        • mikadonovan
          • May 2008
          • 2931
          Ricoh states in the manual that ALL usb drives will not work with their equipment. In all these years I have run into 2 usb flash drives that would not work with my Ricoh units, and they were both PNG.
          NEVER ASSUME ANYTHING
