Pro 8100 SC720-39
  • crisinjomi
    • Feb 2019
    • 14
    Pro 8100 SC720-39
    Good afternoon, I have been reading on the forum the problem of SC720-39.
    My machine jumps once a week and that is when they make many stapled prints.
    I have greased and cleaned SR-5050 and the code appears every week.
    Someone has the same problem and how did you solve it?
    Thanks for your help.
  • anothertech
    • 1766
    Re: Pro 8100 SC720-39
    Bulletin D734-016.pdfFinisher Firmware History.pdf
    Check these, one is a possible interlock SW problem, and the other is a hit in the firmware history.
    • crisinjomi
      • Feb 2019
      • 14
      Ok, I will replace the microswitch and tell you the result.
      Thank you
      • crisinjomi
        • Feb 2019
        • 14
        ok, for the moment everything is going well apart from continuous jams in J114.
          • 37460
          J114, finisher stack output error
          • Di$c0
            • Aug 2009
            • 25
            if i remember this problem correctly........try reducing the number of pages in the prestack. Default is 6
            SP6-225-010.
