IMC2500 Smart Operation Panel
  • windcopier
    • Apr 2019
    • 51
    Hi.
    As i know that the IMC2500 smart operation panel can be internet link access app and browse while using Wifi to connect.
    Does anyone know how to use machine network or using the copier network IPV4 access?
    because some customer only allow using network cable and not allow using wifi for internet.
    thank you for the advice.
  • davel
    • Oct 2011
    • 1107
    Re: IMC2500 Smart Operation Panel
    Same as every other Ricoh device.
    • windcopier
      • Apr 2019
      • 51
      meaning that only wifi can be access either browser or scan to cloud?
      • COPIERMAN
        • Jun 2009
        • 559
        there is two separate things.
        machine setting is where you go for setting up copier for printing and scanning.
        the WiFi is for browsing from smart panel and if you don't connect to there WiFi you can,t browse from smart panel.
        customer can buy a WiFi card optional to install in copier then you can set it up instead of machine setup.
        • windcopier
          • Apr 2019
          • 51
          thank you the info.
          so all the Ricoh Application side feature must link with wifi even scan to cloud to one drive and sharepoint. right?
          thank you
          • COPIERMAN
            • Jun 2009
            • 559
            that is correct that screen feature is tied to WiFi setup. the other ways is to setup the cloud on a pc then scan to it.
            • davel
              • Oct 2011
              • 1107
              You are confusing me, connect device to ethernet and use this internet connection for all functions.
              • windcopier
                • Apr 2019
                • 51
                thanks for the advince. appreciate~
                • windcopier
                  • Apr 2019
                  • 51
                  i already connect with ethernet . But the link with ricoh application side, browsing or even scan to ondrive also can't work.
                  The only way able to connect is using smart operation panel wifi to connect as i know.
                  anysetup can be link with ethernet ? please advice me.
                  • copier tech
                    • 8172
                    Originally posted by windcopier
                    Hi.
                    You can use the web app to browse the net if the machine is on LAN yes.
                    The WIFI in the panel is only designed for mobile printing use.
                    • windcopier
                      • Apr 2019
                      • 51
                      may i know how to on LAN yes?
                      thank you
                      • paulg
                        • Jun 2007
                        • 278
                        The Customer needs a WIFI Access point on the network, so the Smartphone can connect to the network via WIFI.
                        • davel
                          • Oct 2011
                          • 1107
                          Is their LAN connected to the internet.
                          • windcopier
                            • Apr 2019
                            • 51
                            ok. thanks for the advice.
                            • windcopier
                              • Apr 2019
                              • 51
                              Yes. Connect with internet.
