ricoh mpc2800 with sc 533
  • fshead
    • 2376
    HI
    GOT THIS on a ricoh mpc2800 i picked up wth 30k total.
    I looked thru the parts manual and cant find which fan is the IH inverter fan.
    Did not see any fan wth such name to test via service mode..
    thanks
    No.
    TypeDetails (Symptom, Possible Cause, Troubleshooting Procedures)533DIH inverter fan errorThe machine does not detect the fan motor lock signal for 10 seconds while the IHinverter fan turns on.Overload on the IH inverter fan motor1. Check or replace the harness.2.Replace the IH inverter fan.3. Replace the IOB
  • anothertech
    • 1771
    Re: ricoh mpc2800 with sc 533
    D023/D025 SC 533 Drive Unit fan error - replace fan, #B2231332 (right side below IH inverter bd) 04/30/12
    D023/D025 SC 533 Drive Unit fan error - replace IOB 04/30/12
    D023/D025 SC 533 Drive Unit fan error - use SP5-804-121 to check (also called IH Coil fan) 04/30/12
    D023/D025 SC 533 Drive Unit fan error - check/reseat CN 218 on IOB 04/30/12
    • MIGUELMARCHENA
      • Feb 2018
      • 195
      • fshead
        • 2376
        super
        thank you.
        my manual was limited..
        • fshead
          • 2376
          Originally posted by MIGUELMARCHENA
          [ATTACH]43666[/ATTACH][ATTACH=CONFIG]43665[/ATTACH]
          mucho gracias
          excellente yo entiende ahora
          • Mark Bbb
            • Jun 2012
            • 1662
            It can also be that the machine software needs a new F.U. (a fusing reset in other words).
            I cheat the reset procedure with a switch (which i learned here on this Copytechnet site).
            Do you know this procedure?
            Certainly with sc533 this reset procedure is very necessary, with this code, i am not sure.
            • fshead
              • 2376
              I think you are thinking of the mpc3002 series funky pico fuse reset procedure..
              This code i think is just a fan,connector or brd...
              it does come to ready sometimes and I will pull back off and ck fans and connectors....
              thanks
              • fshead
                • 2376
                danm truckers moving electronics like it is lumber...............
                • fshead
                  • 2376
                  Originally posted by fshead
                  mucho gracias
                  FAN WAS to the left of the right side door..........
                  • fshead
                    • 2376
                    i meant to say fan was to the right of the right door and left of the controller..
                    Its odd they bent the metal brackets,fan but all outside plastic was in one piece and perfect..X MEN ??
                    • Zaxxon
                      • 608
                      Send them a bill
                      Please start you post with brand, model, problem.
                      • fshead
                        • 2376
                        Originally posted by Zaxxon
                        Send them a bill
                        WHY waste the paper..
                        I recently ad a nice mp6002 wth low meter shipped up from down south.
                        They warehouse barely wrapped it in plastic and the front door and all trays banged open
                        and close for 1500 miles.
                        I had to pull all the metal brackets and reform everything..
                        my complaints went unheard
                        • anothertech
                          • 1771
                          Send them a bill
                          or send them the whole duck.
                          • guitar9199
                            • Sep 2016
                            • 1100
                            WOW!!
                            Yep... that'll do it alright!
