mpc3002 jam between F.U. and exit
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    Wrinkled paper caused by paper catching behind - always the same - tooth of the exit / duplex junction gate.
    Checked junction gate "teeth"for cloged toner = ok // checked the power of the solenoide - because it could be that J.G. solenoide has not enough power to completely revoke = ok (remove little front panel and you can see the solenoide is working) // swapped with good working exit unit = no good // checked PTR and the position of the transfer roller = ok, no broke parts (I even swapped PTR) // ITB = ok // Image on paper is ok (no skew or loss) // replaced Open close duplex enterance guide // client tells me problem came up all of a sudden.
    I think the F.U. is causing this... What do you think?
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc3002 jam between F.U. and exit
    i can't seem to upload any photo's?
    • Zeldaman
      • Mar 2011
      • 946
      • Mark Bbb
        • Jun 2012
        • 1662
        Hoi Zelda:
        Thanks, but paper wouldn't be wrinkeled if it was that motor, i think ???
        • Zeldaman
          • Mar 2011
          • 946
          • FrohnB
            • Jul 2017
            • 1919
            What's your jam code?
            Have you checked the registration guide? Sometimes the mylar gets torn and paper can hit on that and cause a jam down the line.
            Static Teeth on PTR bent up?
            Fuser guides have toner build up? Warped? Missing the little "white guides" on fuser exit guide? Stripper Plate warped?
            Can you swap feed units between 1 and 2 to see if it follows that?
            Omertà
            • Mark Bbb
              • Jun 2012
              • 1662
              F.U. Guides are clean.
              Forgotten to mention: I have also swapped the F.U. with a referbished one (but it might be that this F.U. is also not so good)....
              Registration guides checked, in fact i checked the whole paper path..., clean!
              I am somewhat creative in referbishing F.U.'s and it could be that i have been to creative...
              Tommorow i will insert a new F.U. and let you know.
              Thanks.
                • 37642
                Mark Bbb, you have been around here long enough that you should by now know that it is important to include the jam code.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Replaced F.U. with a new one, no good.
                  We think it is a registration problem, because the L.E. image has moved to high; copy from Ricoh test chard only shows the 6 mm line at L.E.
                  I will investigate that and let you know.
                  Slim, Jam location 020 018 024
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      appendix:
                      problem is with all the 4 trays.
                      Registration via SP mode affects the image to move, but not enough
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        anyone?
                          • 37642
                          Originally posted by Mark Bbb
                          anyone?
                          Jam code???
                          • Gary Bowen
                            Bowdog
                            • Mar 2008
                            • 250
                            Have you tried adjusting the Buckle with SP 1003-002 for Tray 1 (Plain)? I know you said all 4 Trays exhibit the same problem but its worth a try. Tray 2/3/4 all are adjusted with SP 1003-007 (Plain).
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Same player shoots again
