Ricoh MP301 Email issue
  • digicor
    • Jul 2008
    • 1153
    Machine was working pefectly, clien had a router go down, new router put in office, print, is fine, he has internet and email, yet, the email scan wont work from the machine, its says "standby"
    i have the ports open in the router, its not a different company.... anyone have this issue?
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Ricoh MP301 Email issue
    check gateway, SMTP server and the email address that you put in the machine
    • solorajder
      • Jul 2010
      • 106
      Did you look if the Default gateway or DNS was changed?
      Sent from my G8441 using Tapatalk
      • digicor
        • Jul 2008
        • 1153
        yes smtp sever and all parameters are checked and i can ping my smtp server
        gate way, dns are all good
        • solorajder
          • Jul 2010
          • 106
          Does new router have the same IP as old one?
            • 37448
            From the MP 301?
            • Mark Bbb
              • Jun 2012
              • 1662
              perhaps there are working since the router was replaced with office365 mail or Gmail?
              • digicor
                • Jul 2008
                • 1153
                yes it is the same
                • digicor
                  • Jul 2008
                  • 1153
                  they use ehot mail.... yuk,
                  my email server is through spectrum, i have it set up for my business and use it on over 100 clients...
                  i think it has to be in the new router, or the new router is defective?
                  i have never had to mess with a router unless we were installing 2 separate gateway's for two separate lans in the same building
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    • digicor
                      • Jul 2008
                      • 1153
                      i agree totally,
                      ill check and see
                      • Trommel
                        • Oct 2019
                        • 29
                        As it happened right after the router has been changed I'm also guessing it has something to do with the new router - if no other device has been newly integrated as well.
                        If it's a smaller network with no device restrictions / port security etc. you could just take a test notebook with the same IP as the ricoh machine when it's shut down and test it from there, for example with windows telnet, so you actually know whether you can reach your smtp server through the specific port.
                        What ports have you opened and how is it configured? If you just want to send an email with SMTP and it's a small router with a normal integrated firewall and no other server/proxy used, you don't really need any ports open as you send the smtp request only from the inside of the network to the mailserver through NAT. It's just guessing from my part though without knowing more about the network.
                        • digicor
                          • Jul 2008
                          • 1153
                          all ports >25 (greater than ) are open in the smtp section,
                          ill try the ip address with a lap top and just see if its the problem, thanks for the insight
                          • StephenB
                            • Aug 2015
                            • 240
                            If all your network settings - IP (no conflicts on existing network devices) subnet mask, gateway, DNS servers, SMTP servers are all the same...there may be another issue with the outgoing server or incoming server.
                            Just had 2 weird email problems today an hour apart... both Spectrum (Brighthouse) could not scan to email to their Domain emails. They could send to a gmail account. I suspect maintenance or glitch at Spectrum
                            • digicor
                              • Jul 2008
                              • 1153
                              thats funny,i had the same issue a one of my clients! but in my case the email woulndt go to my gmail either, but my office MFP (same set up smtp outgoing) worked fine!
                              did it get resplved?
