MP3352 Light streak/Void
  • Hadster
    • Aug 2011
    • 264
    Light Streak on front edge.
    I have replaced: 2= Brand new OEM PCU's, Transfer roller AND Laser unit. Even though the streak happens with both copy and print I have cleaned the optics. ??????? WT*
    BTY- I am using Type 1027 PCU's like I have been for years with no issuesTest copy.jpg.
  • HitMan
    • Aug 2015
    • 170
    Re: MP3352 Light streak/Void
    Are the guides aligned correctly in the tray?sometimes the white gear can jump and the guides don't align correctly. Also what happens if you open the scanner and take a sky shot does the image print on the full page? Could be a mag or reg issue that just needs adjustment
    Sent from my SM-G930F using Tapatalk
    • copyaction
      • Oct 2007
      • 991
      Did you stop it midway through and see if the image is on the drum?
      • Hadster
        • Aug 2011
        • 264
        Yup, checked trays. Tried out of tray 1 and 2 with same result. They are centered. Here is the sky shots... one with the dust cover and one without the dust cover. I can't figure why this is making a difference since I tried swapping out the laser unit. I reinstalled the original laser unit so I wouldn't have to re-adjust.
        • HitMan
          • Aug 2015
          • 170
          Is something in the path of the laser? What about the discarge plate? Is that working
          • Hadster
            • Aug 2011
            • 264
            Not finding anything blocking the laser. Looks like it when it prints though. Weird!
            • HitMan
              • Aug 2015
              • 170
              Did you also try this?
              • Hadster
                • Aug 2011
                • 264
                Yes, it's not on the drum.
                • HitMan
                  • Aug 2015
                  • 170
                  And the laser slit glass is clean and fully pushed all the way into its seated position?
                  • Hadster
                    • Aug 2011
                    • 264
                    Take a look at my response with the sky shots. I mention this with slit glass and without.
                    • HitMan
                      • Aug 2015
                      • 170
                      What happens if you reduce the image?
                      • Hadster
                        • Aug 2011
                        • 264
                        • HitMan
                          • Aug 2015
                          • 170
                          Remove the slit glass??? [emoji1787]
                          • Hadster
                            • Aug 2011
                            • 264
                            Yup! I was just checking at first to see if it was dirty causing the issue. Full image @ 93%.
                              • 37637
                              What you are seeing is edge erase. If the paper in your attached photo is ran SEF, short edge feed, adjust SP 2103-001 Leading edge erase and SP 2103-002 trailing edge erase. For LEF, long edge feed, adjust SP 2103-003 and 004.
