ricoh fax forwarding
  • dalewb74
    • Feb 2018
    • 1162
    i have read another post on here. but was hoping someone has figured it out now. can fax forwarding to multiple emails be setup? and if so what is the process? i have been trying with no luck. i click on add group and create it. but it doesnt show up as an option for the destination. i would think surely it could be done. otherwise what is the point of even having the group option if it does nothing. i was gonna look in the user guide. but being a new model there isnt even an user guide for download on ricohs website. thanks for any input.
  • ridgemill
    • Sep 2017
    • 191
    Re: ricoh fax forwarding
    What is the model?
    • FrohnB
      • Jul 2017
      • 1919
      Did you try selecting your "forwarding group" as the forwarding address? Saw this on the Ricoh forum.
      Omertà
      • dalewb74
        • Feb 2018
        • 1162
        the model is the IMC4500. and when i try to select the group that i created, that group is not an option for forwarding.
        • zed255
          How'd ya manage that?
          • 1024
          When you created the group you did in fact add existing individual entries to the group, correct? That is, you aren't mistakenly trying to use an empty group.
          Can you send a scan to this group? If you can't scan to it it won't forward either.
          • COPIERMAN
            • Jun 2009
            • 559
            zed255 is correct first create users then add them to group
            • dalewb74
              • Feb 2018
              • 1162
              yes i have created the users and the group. as i mentioned then once i go to select the group it is not an option. yet i can go in and edit said group and even add a new user if needed. the group i created has 2 users in it. each user is set with that persons name and email address. though keep in mind i want to forward faxes to this group. as far as emailing multiple users at one time, no issue.
              • tinfox
                • 317
                I know you want to get this working correctly, but if you're in a pinch, you can set up an email alias on their server or Gmail and forward the emails to their addresses.
                Sent from my moto e5 supra using Tapatalk
                • dalewb74
                  • Feb 2018
                  • 1162
                  yeah have thought about that one as well. though it will require a bit of working with their IT dept. was hoping to do everything on this end. but its looking more and more like that is the only option available. kinda strange that you can send to multiple users for other stuff, but are limited to just one for fax forward to email.
                  • tinfox
                    • 317
                    To avoid the I.T. dept, use a new Gmail account.
                    • dalewb74
                      • Feb 2018
                      • 1162
                      good idea, but its a financial institution so that wouldn't fly. they monitor everything. but thanks for the suggestion.
