Strange problem with Ricoh mp7500
  • m_donakov
    • 213
    #16
    Re: Strange problem with Ricoh mp7500
    Originally posted by Gary Bowen
    Just for the record the Type 8000 Print/Scan SD Card is unique to the D052 series only which is the MP 6000. The correct Print/Scan SD Card for the MP 7500 is G338 (which is the Type 1075).
    I have and old Ricoh 1075 with working printer controler should i try to change the sd card from that machine?
      • 37490
      #17
      Incorrect. The type 1075 is for the Aficio 1065/1075 and is a DIMM not an SD. The correct Print/Scan SD Card for the MP 7500 is B841 Printer/Scanner Unit Type 7500.
        • 37490
        #18
        Ricoh does not use SD card. Printer/Scanner is a DIMM that mounts in Slot1 on the Controller Board. It uses PCMCIA memory cards for firmware updating.
        • m_donakov
          • 213
          #19
          Ok than i need to find printer scanner sd card type 7500. I cant understand why in this machine is type 8000 sd card. Somebody before me change it.when i first saw that card, i thought it wouldn't work but it works but it does cause problems.
          One more thing I would like to ask you, is there any chance the machine to have mp 8000 printer built-in?
          Since second hand machines from Switzerland are imported to our country I was wondering if it was possible that they imported the machine without a printer controller and have it installed here?
          Thanks to all of you
            • 37490
            #20
            You could see if you can order it from Ricoh. EDP code is 412907.
            • Mark Bbb
              • Jun 2012
              • 1662
              #21
              Originally posted by KenB
              How about clogged ozone filters, or a failing cooling fan?
              Bad airflow equates to excessive heat and static.
              That would explain why it performs better with the door open.
              Ozone filters tend to be a VERY overlooked maintenance item.
              +1 !!!
              • m_donakov
                • 213
                #22
                Tried without filters and with out back cover still problem
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  #23
                  You write in your first thread: "I must reset it with 107 off and on"
                  Which SC code appears than?
                  • m_donakov
                    • 213
                    #24
                    No code nothing in sc history nothing
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      #25
                      I think :
                      OR paper is stucked for a while under the drum, OR the movement of the drum or development roller is interrupted.
                      Do you hear a certain noise when it happens?
                      • m_donakov
                        • 213
                        #26
                        I think :
                        There is no special sound. The machine stops as if it wants to do a self check. Then the next sheet gets stuck. If I remove it, it keeps getting stuck until I reset it
                        • trc
                          • Jan 2007
                          • 95
                          #27
                          Check 7-403 for internal errors. Could be cleaning web motor, or corona cleaner motor.
                          • m_donakov
                            • 213
                            #28
                            There is no error code, but i dont think that can be a problem, i have 10 machines with unplugged charge corona cleaner and they work well.
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              #29
                              A printer sometimes stops at regular intervals for ID check, is this the case?
                              Or is there another reason why it stops? Perhaps to load toner?
                              I think that is the cause of the problem.
                              Perhaps a grounding problem?
                              • m_donakov
                                • 213
                                #30
                                I think is stop for ID check, And I thought maybe there was a problem with the grounding that was my next thing I wanted to check
