Strange problem with Ricoh mp7500
  • m_donakov
    • 213
    [Jamming] Strange problem with Ricoh mp7500
    Hi all
    I have a weird problem with a ricoh mp7500 machine. There is no code but sometimes it will print 5,000 sheets without a problem but sometimes gets stuck on every second sheet and the copy is deformed. as you can see from the pictures.To continue working I must reset it with 107 off and on. Firmware update 2 days ago still has the same problem. as you can see the text is compacted and should be a4. Or sometimes the text is twisted. The same problem is encountered when printing and copying
    Please I appreciate your every opinion
  • GIUBOSS
    • 1433
    Re: Strange problem with Ricoh mp7500
    do the tests with the door open ... check if the drum turns correctly. 107 generally restores fusing errors. Didn't you check anything inside the various units if everything is okay?
    • m_donakov
      • 213
      I think it's better with the door open, I haven't tested it but when I had a large print series I worked with the door open to have better cooling and I don't remember well but I think it was better. And what about the door? What can happen to the door to make trouble? Please advise me what to check in the Fusing Unit and on the drum unit, At first glance it looks like everything is fine
      • m_donakov
        • 213
        It is very strange to me that after the problem the machine printед 500,000 pages Resetting it . Whatever it was mechanically it would break down completely. And no SC Code in SC history ?
        • GIUBOSS
          • 1433
          working with the open door is not the solution but only to see inside the paper transport phases. It's just a case that it goes well. Can you control the PM parts like drum, blade, developer, fuser rollers how many pages did they do? How many total copies does it have?
            • 37480
            What are the PM counts, especially on the development unit. In your samples I am seeing signs of a dirty doctor blade, depleted developer and uneven developer distribution.
            • m_donakov
              • 213
              Developer drum an drum blade Change before 100.000
              Total 1.600 000 copies
                • 37480
                That is not what I asked. I asked about PM counter. If you do not know how to get the PM counters, you should not be working on the machine.
                • m_donakov
                  • 213
                  I can see pm counters but they arent real becouse they arent reseted when parts are changed. I write on paper all services that i do so drum drum blade charge corona and grid and developer are changed before 100000 copies. Fuser teflon and fingers are changed before 200 000 and stil looks fine. Transfer is checked swaped from working machine same problem. Firmware updated. Checked hard diak and everthing is ok. Tomorow i will test ram memory and dont know what to do else. Thanks
                  Ps. Printer / scanner sd card is type 8000 i dont know if its ok that card on mp 7500 machine.or somebody before me change it
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    How about clogged ozone filters, or a failing cooling fan?
                    Bad airflow equates to excessive heat and static.
                    That would explain why it performs better with the door open.
                    Ozone filters tend to be a VERY overlooked maintenance item.
                    • GIUBOSS
                      • 1433
                      help you solve the problem I agree but if you don't know the machine you risk doing more trouble than repairing, explaining everything to you about repairing an mp7500 there are technical manuals. Trust me, I've experienced it on my skin too ...
                        • 37480
                        Since you have not been clearing the PM counters, you need to do a complete PM and then clear the counters.
                        As for the SD card type, Ricoh uses the fastest model that the card can be used with as the type.
                        • Gary Bowen
                          Bowdog
                          • Mar 2008
                          • 250
                          Just for the record the Type 8000 Print/Scan SD Card is unique to the D052 series only which is the MP 6000. The correct Print/Scan SD Card for the MP 7500 is G338 (which is the Type 1075).
                          • Lagonda
                            • Aug 2008
                            • 1649
                            I haven't seen these copiers for awhile but we used to get a problem with the screw that held the drive dog to the rear end of the drum shaft falling out. The shaft used to slip then grip causing random compressed lines across the copy.
                            • KonMan
                              • Mar 2010
                              • 15
                              Nu Finish car polish. Polish the drum. No more problems.
                              Sent from my SM-T378V using Tapatalk
