MP 6503 sc 664-002
  • mikadonovan
    • May 2008
    • 2931
    MP 6503 sc 664-002
    Hi, All. I have a MP 6503 that worked great in the shop, but when we delivered it and fired it up, it shows some Chinese characters and a sc664-02 which is a vodka error. Never even heard of it. Has anyone ran into this before?
    NEVER ASSUME ANYTHING
  • Kimi
    • Feb 2018
    • 105
    Re: MP 6503 sc 664-002
    vodka? its drank too much or needs more??
    • mikadonovan
      • May 2008
      • 2931
      You would have to ask a Ricoh design engineer, they named it. Com error between IOB, BICU, SRAM.
      • GIUBOSS
        • 1428
        • mikadonovan
          • May 2008
          • 2931
          Ok, the machine is running OK and is at the customers office. In shop I pulled the fax and G3 unit off, reseated all connectors on the IOB, BCU, and controller. The sata connector for the HDD on the controller was loose, so I just hot glued it down after straightening the pins. I replaced the HDD. After I fired it up all was well, no Chinese characters or sp access issues, or sc 664 codes. I then installed the fax unit, and all the icons on the SOP display disappeared (not good). I removed the fax and they returned. Needless to say, the machine was delivered without the fax installed. Time will tell if it is going to work well. Thanks for the replies, and everyone have a great weekend!
