ricoh mp c4000
  • cliffhangers
    • Feb 2010
    • 243
    ricoh mp c4000
    Please just one to no if i can change the polygon mirror whithought changing the memory board?my own is bad.thanks in advance
  • GIUBOSS
    • 1437
    Re: ricoh mp c4000
    if you expose the problem first ... error code? I believe they are two different failures.
    • Codex
      • May 2008
      • 705
      Re: ricoh mp c4000
      You mean only the rotating part?..... Why should you do that?
      Inviato dal mio SM-G935F utilizzando Tapatalk
      Memento Audere Semper
      • davel
        • Oct 2011
        • 1109
        Re: ricoh mp c4000
        If you have a polygon motor error just change that, if blank screen with hidden SC code motor and BICU board.
        • fshead
          • 2378
          Re: ricoh mp c4000
          I say no.
          I use to pull panafax poly motors apart and lube the shaft wth triflow but on these ricohs the issue is the board transistors blow thru
          with bad solder joints..Maybe overheating or just bad mechanics..You can see it if you look..
          might be able to cross over from other models,mpc2800/mpc3300/mpc3501 as a lot of this design didnt change
