MPC 3000-paper problem
  • tavorh
    • Sep 2016
    • 25
    Hello everyone, I have a problem with the mpc3000 machine.
    The machine makes the paper wrapped when it comes out, so it makes it look like it's wet. I have tried more different types of quality paper, but it didn't get any better. So, does anyone have any idea on how to fix this?
  • mincopier
    • Dec 2015
    • 290
    Re: MPC 3000-paper problem
    Normally this is a sign that the paper has moisture in it before it even goes through the fuser section. Does not always have to do with the quality of the paper. Try another fuser.
    • fshead
      • 2356
      open a fresh ream 1st and try that..
      If it is getting moist from sitting try to see if you can add a tray heater..
      • GIUBOSS
        • 1382
        try making blank copies and return the sheets to the paper tray, so you get drier paper and compare the result. Is the paper 80 grams?
