5210 ADF Adjustment
  • ABS tect
    • Sep 2013
    • 511
    5210 ADF Adjustment
    I for the life of me cannot figure out how to adjust the top to bottom registration of the second page while copying through the adf on a 1 to 2 sided document on the 5210. Any help?
  • fshead
    • 2376
    Re: 5210 ADF Adjustment
    I had issues wth a that series on a guy who did all double sided scanning.
    I ended up cleaning all rollers wth wd 40 especially thes that release when you open the lid..they get real dirty and the ones
    with the sponge on the side on the exit..
    I ve only had to adj lead edge via sp 6??? something to fine tune..
    • ABS tect
      • Sep 2013
      • 511
      Thanks man...Yea ive never had a machine give me more headaches when trying to get everything straight.
      The first thing i have to do before anything is actually get it to feed straight, and for that i take the 2 screws off of the right adf hinge and move it, and sometimes that still isn't enough. Then i go through the sp 6xxxx and can get a one sided copy about perfect with the trimming edge. And 2 sided - 2 sided also is fine. But when i try to make an adjustment for 1-2 sided it doesn't work. I mananged to get the left to right somewhat adjust (though not fine tuned) through copier features in user tools...however still no luck with top to bottom. I feel like ive tried everything and the top is still getting cut off.
      • fshead
        • 2376
        That feeder is the same as the mpc300/mpc401 and it is a little cheap with the hinge design..
        I always find if i close the lid i can always see there is always some play..
        Like you I fudge settings to make it past what the customer needs..But I do knowthe 2 rollers above slit glass get real funky and
        I run test motor mode with paper between them wth wd 40 and a lot of black comes off..
        • ABS tect
          • Sep 2013
          • 511
          Oh cool idea...thanks man ill give it a shot. I appreciate it
            • 37556
            ADF adjustments can be a bitch. They can be even worse if you do not adjust from the platen glass first.
            • ABS tect
              • Sep 2013
              • 511
              Absolutely...i always start with the tray...to the glass...to the adf
