MP c5504 No USB
  • Timmytronic
    • Oct 2010
    • 249
    MP c5504 No USB
    Hiya, I have a machine that has the usual USB slot in the control panel for the customer to print from or to scan too if required and on this one machine, the USB does not show. I have made sure the USB is Active on the control panel. Am I missing something? I have looked in Scan too and it only shows the HDD or in Print from storage it does not appear either. They have another machine the same and it works on that so its not the USB sticks we have tried.
    Thanks loads, Tim
  • FrohnB
    • Jul 2017
    • 1919
    Re: MP c5504 No USB
    Are you putting the SD card in first and then going to the print or scan screen? Had a library call in about this a few weeks ago.
    Had her go to the print or scan screen FIRST, then hit "Print from memory storage device", THEN insert the card, and it should show up. Kind of weird, but that's how we've gotten it to work.
    Omertà
    • illude2
      • 30
      Re: MP c5504 No USB
      Do they have the media slot disabled in Web Image Monitor?
      • Zeldaman
        • Mar 2011
        • 946
        Re: MP c5504 No USB
        Hi there1
        FrhonB is right, it only runs this way.
        Greetings...
          • 37628
          Re: MP c5504 No USB
          In older models that did not have the SOP you had to install the USB2.0/SD Card Slot option. Part of that was change Scanner SP1013-001 from "0" to "1" and/or Printer SP1110-001 from "0" to "1". With the SOP those can be used to disable the USB slot on the panel.
          • mikadonovan
            • May 2008
            • 2931
            Re: MP c5504 No USB
            Boy, I am glad you posted this. I just last week had someone bring to my attention that a 6503 could not scan to a usb flash drive, and this was why. Mucho thanks.
            NEVER ASSUME ANYTHING
            • Timmytronic
              • Oct 2010
              • 249
              Re: MP c5504 No USB
              • Dan G
                • Nov 2014
                • 56
                Re: MP c5504 No USB
                Tim is it not recognizing a USB or SD card at all? I had a CW2200 that wouldn't recognize one after I knew it did previously having tested on said machine before. In the End after backing up NVRAM first I went through each memory clear one at a time because an all clear did fix it. I reloaded NVram then systematically cleared each memory and reloaded NVRam each time to determine which worked Turned out the fix was clearing the SRM (system Resource Manager) Memory SP 5801-18 and wala it can see the USB again
                • dalewb74
                  • Feb 2018
                  • 1167
                  Re: MP c5504 No USB
                  trying reformatting the usb drive. if its ntfs i would try fat32. and the files usually have to be .jpg or pdf. i know you mentioned it worked on another machine, but that is something to try. i have had mine work before on one and not the other.
                  • Brianneoe
                    • May 2015
                    • 322
                    Re: MP c5504 No USB
                    I had this problem on a 03 color machine. Turned out that the problem was that the copper connectors was bent down due to the end users jamming their usb sticks in over and over again. Took it all apart and reshaped the connector..all is working.
