Ricoh Pro C751 - Network Configuration
  • forumoto
    • Nov 2019
    • 15
    #16
    Re: Ricoh Pro C751 - Network Configuration
    There are 2 network jacks only if the gigabit connector is installed for the Fiery. The gigabit connector mounts on the GW controller. The GW controller is disabled in SP when the Fiery is installed but it is still there. The Fiery installation instructions have the SP changes. Undo those changes to enable the GW printer function.
    The other jack is the network connection for the C751. It is used for WIM and other normal network activities.
    Am getting confuse about all that am reading currently about this printer, in fact this will be the first time am about to setup a large printer of this system and I have done for other brands but this Ricoh is getting my heart beat up too much... I am really confuse, thanks to all who are supporting me with explanation.. I wish this can be done via team view, like I would like someone who is knowledgeable to get on board and help me on the fiery machine to configure this please
    • eccelobo
      • 113
      #17
      Check your PM
      Good Luck!
      • forumoto
        • Nov 2019
        • 15
        #18
        Having issue with this error code displayed -:
        SC590-02
        i need help on this, this has to do with C751 copier /printer
        attached are pictures of the rear back of the right drawer. I would like to see which stepper motor is the culprit or If I have to replace the drb board let me know. Thanks
        • davel
          • Oct 2011
          • 1089
          #19
          SC590-02
          Nothing to do with OP, start a new thread.
            thanks ... i see this thread going down the same road..
            they start a thread.. don't mention all problems
            then three months later we are still dealing with the problem...
            reminds me of a thread about "Lines of shame".... we gave the guy the fix... he dinny follow directions..
            told US we didn't give him all the proper steps, (EVEN when he was provided with the actual setup instructs for that Bizhub unit)
            he got it right then had a 'firmware issues'? did an all clear and it started from square one with him..
            I since have blocked him... can't stand stupid people (THIS comment IS NOT meant for anyone in this thread)
