Ricoh Pro C751 - Network Configuration
  • forumoto
    • Nov 2019
    • 15
    I would like to know or I want to know the steps involve in hocking this printer to the network via cat 6 cable, using rj45.
    i will also be grateful if someone can share with me the printer drivers, and also how to input the IP address and subnet ip .
    thanks
    the printer is in Spanish as well, I will like to change it from that language display to English.
    • 37489
    Re: Ricoh Pro C751 - Network Configuration
    That depends on whether or not there is a Fiery involved.
    Drivers can be downloaded from Ricoh.com.
    thanks
    There should be at least 2 languages installed. They are selected in User Tools. If the language you want is not available there, you will have to install the language firmware and select language(s) you want.
    • forumoto
      • Nov 2019
      • 15
        • 37489
        No. I meant that the connection is different depending on the presence of a person Fiery.
        • forumoto
          • Nov 2019
          • 15
          Do you mind, if we can chat on skype, I think that would give us better quick messaging.
          Do you have any tutorial or video or step by step Manual to read in other to get this setup.
          Does it means that the c751 would have to connect to the server computer and then from the server computer to the network.
          can you connect it direct to the network without the sever computer and have it setup as a standalone printer taking command from which ever user computer on the network which will be configure to send printing command to .
          pls sorry for my English though, it is not my first language
            • 37489
            Again it depends on whether or not it is configures to use with a Fiery. Get a service manual. Download the Operator Manual from the same Ricoh site as the drivers. The operator manual will include installing on a network.
            • bojans
              • 1313
              As far as I know, this machine can only print with Fiery attached. There is no option to print without Fiery.
              • jacques
                • Nov 2019
                • 3
                Configuration.pdfConfiguration.pdf
                hi, this the Fiery setup manual.
                • forumoto
                  • Nov 2019
                  • 15
                  thanks for making it clear and open, I thought there is a way you can attach it to the network direct. So looking at it, would the machine be connect to the fiery then to the network or the machine will be connected to the network via Ethernet cable, then fiery also be connected to the Network via Ethernet cable, then how would this fiery manage the printer, hmmm
                  • jacques
                    • Nov 2019
                    • 3
                    the PRO C751 has 2 network interface connectors, the 1st one is for the network and the 2nd one is to use smb/ftp scanning. Connect the LAN cable to the Fiery and then CONNECT THE NETWORK CABLE RJ45 from the PROC751 to the Fiery.
                    On the Fiery You need to assign it an IP Address which You can either do on the Fiery or via the Command Workstation software that is part of the PROC751 software.
                    The proc751 does not have a print controller software and the print icon only appear once the Fiery is connected
                    • forumoto
                      • Nov 2019
                      • 15
                      many picture, available, of this connection,
                      secondly I need your help also on how to change the language on the main printer, currently it is Spanish, want to change to English. Help on that
                      • jacques
                        • Nov 2019
                        • 3
                        see attached
                          • 37489
                          Then someone has configured it to use the Fiery. Part of that configuration is to turn off the GW printer function in SP.
                          • dalewb74
                            • Feb 2018
                            • 1153
                            ricoh support can talk you through a process which basically will disable the copier from looking for the attached fiery system. i have done it on another production ricoh. it is a long drawn out process, but can be done. though surely you know the benefits of having the fiery system installed? if you already have the pc i would run with that.
                              • 37489
                              There are 2 network jacks only if the gigabit connector is installed for the Fiery. The gigabit connector mounts on the GW controller. The GW controller is disabled in SP when the Fiery is installed but it is still there. The Fiery installation instructions have the SP changes. Undo those changes to enable the GW printer function.
                              The other jack is the network connection for the C751. It is used for WIM and other normal network activities.
