Ricoh MP 501 / 4055 Classic Icons disappearing
  • aaa
    • Mar 2013
    • 8
    We have a Hospital that their IT, keeps saying this is happening on different MFPs.
  • Zaxxon
    • 608
    Please start you post with brand, model, problem.
    • Dan G
      • Nov 2014
      • 56
      Re: Ricoh MP 501 / 4055 Classic Icons disappearing
      ensure all firmware including java and operation panel OS and apps are up to date - should fix the known issue
      • Coptech
        worker drone
        • 460
        I think in the system settings, there is a reset SOP to factory defaults button that is way to easy to access that removes the classic applications. My bet is the IT dept is causing your issue not knowing they are responsible.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          • DRichard
            • May 2008
            • 482
            Oh...it's not even in the system settings... IT'S ON THE EFFING OP PANEL!
            "Enjoy every sandwich."
            -- Warren Zevon
            • mikadonovan
              • May 2008
              • 2931
              Yea, ex buttons on the left side.
              NEVER ASSUME ANYTHING
              • DRichard
                • May 2008
                • 482
                Look at the botton of your SOP, immediately to the right of the "house" icon. The stack of three horizontal lines will reset your Smart Op-Panel configuration to Ricoh's preferred panel appearance. Right where any user can push it...unless the screen has been locked by an office manager or such.
                -- Warren Zevon
                • mikadonovan
                  • May 2008
                  • 2931
                  Thanks, that is good to know.
                  • aaa
                    • Mar 2013
                    • 8
                    Thanks for the advice, I will look into that option.
                    • dalewb74
                      • Feb 2018
                      • 1125
                      does it have the simple screen?
                      • aaa
                        • Mar 2013
                        • 8
                        Yes. I told their IT to make sure someone isn't resetting Home screen to factory also.
                        • mavetherave311
                          • Oct 2012
                          • 11
                          turn on administrator authentication,this will disable the"reset home screen button"
                          • Zeldaman
                            • Mar 2011
                            • 946
