MPC3503 Java ?
  • GeorgeBest
    • Jul 2009
    • 526
    MPC3503 Java ?
    Hi
    Anyone know if Java is standard on this machine?
    Got a call from customer that it is missing?
    thanks in advanve
  • illude2
    • 30
    Re: MPC3503 Java ?
    Java v11.** is standard and included with the machine. v11.41 is the newest available.
    • zed255
      How'd ya manage that?
      • 1024
      Re: MPC3503 Java ?
      For clarity, Java on these is embedded in a flash ROM on the controller, so you won't find a Java SD card. Also, Java can be disabled via SP mode, some where in the SP5-730ish region (check the service manual).
      • skinnyb
        • Jul 2008
        • 291
        Re: MPC3503 Java ?
        This. Java is embedded in the controller flash rom on this model and is standard. You can disable in service mode. I do on occasion with customers who do not use it. Makes the machine boot up faster
        Sent from my LM-V405 using Tapatalk
        • luca72
          • Oct 2017
          • 1784
          Re: MPC3503 Java ?
          Originally posted by GeorgeBest
          Hi
          thanks in advanve
          Sp5730 set to 0
          Java off=turbo mode
          "I'll be back"
