MP9000 Firmware update problem
  • vitorjorge
    • Dec 2008
    • 9
    Hi
    In a Ricoh Mp 9000 i have installed a system copy firmware 6.03. but i did't install the engine firmware 5.19:20 or higher first.
    Now when i turn on the machine the message is please wait
    How do i reinstall the older system copy firmware?
    The reason i put the system copy firmware 6.03 was to solve sc 990 991
    TANKS
  • Eric1968
    • 2458
    Have you tried to boot the machine without the HDD connected?
    I've had the same with a Aficio 3030 (HDD defective).
    • Shadow1
      • Sep 2008
      • 1642
      73 DE W5SSJ
      • pro.b.unal
        • Dec 2008
        • 42
        hi. the return firmware factoyry defult procedure.
        1.show on the eror' E-24,32,34 ' on the operation panel, enter the '143' and three Blue C key hold, listen to ''biip'
        2. torn off the machine , torn on the machine (install firmware factory deafult)
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          Originally posted by vitorjorge
          Hi
          TANKS
          Hi, there is no turning back you´ll have to order the BCU board for the new pro series:
          D101 5220 PCB:BCU:Ass'y (Model C3.5)
          this is the small board that fits into the io board, this board comes with the other firmware you need to boot up your machine, then just update the rest, LCDC, amimation and so on, all the firmware. remember that the LCDC firmware takes about 25 minutes to upload. From now on all firmware related to your machine is D101 XXXX for the new series, Your machine is now a Pro 906EX theres no turning back.
          If you need any help contact me thru PM.
          Just order the board and you´ll be back in business in 5 minutes.
          Hope this helps.
          sigpicWe can all Win, but at the end we all loose. Save the greyhound
          • vitorjorge
            • Dec 2008
            • 9
            Tanks all of you guys for the quick help
            i tried to boot the machine without the HDD....
            i tried to boot the machine with dip switch 1 at "1"
            I tried the "143" 3* "C"
            None of that worked
            I'm ordering a new BCU board tanks to iMind tip.
            I'll keep you posted
            Tanks
            VJ
            • Ricoh-ono
              • 338
              I know this is a little late but here is the TSB for updating firmware from the B234 to D101 series. I had one hang up even though it was done correctly. It took out BCU, Controller, NVRAM, System Card, and the Interface board.
              Do what you can, with what you have, where you are. ~Theodore Roosevelt
              • FRIDGEMAGNET
                • Aug 2007
                • 377
                Hi Guys.
                I have had this same problem and it is possible to recover from it.
                You will need to get a system card from another working MP9000/1100/1350 that has not had the firmware updated to the new levels.
                Swap it with the problem machines system card and then this will allow it to switch on - you can then update the engine. Next swap the cards back and then update the system to the new level.
                Remember that you need to update EVERY bit of firmware to the latest level - if you don't then you get some weird things happen like hanging before going into SP mode and parts of the display missing.
                It is very important to do the procedure in the correct way - Engine - System and all the rest after that. Now I always now do the 1st 2 one at a time and then the rest all together.
                • vitorjorge
                  • Dec 2008
                  • 9
                  Originally posted by FRIDGEMAGNET
                  Hi Guys.
                  You say that i need a system card from another working MP9000/1100/135.
                  My question is can i order a SD-Card Copy (Model C3) B2345450 and do the procedure that you say?
                  Tanks
                  • FRIDGEMAGNET
                    • Aug 2007
                    • 377
                    Tanks
                    Hi
                    Yes you can order one B234 5530 SD-Card Copy (Model C3).
                    • vitorjorge
                      • Dec 2008
                      • 9
                      Problem solved
                      Today i went to the client with two solutions
                      1 SD-Card Copy (Model C3) B2345450
                      1 PCB:BCU:Ass'y (Model C3.5) D101 5220
                      The first attempt was made with the SD card on slot 1 and one SD containing the engine and system firmwares.
                      the machine give me a SC 8xx don't remember exactly.
                      My sd card was 2G formatted in fat but something didn't worked, so i used a SD card of 16M (fax address card) formatted in FAT and the latest engine firmware.
                      The upgrade was successfully.
                      I needed to upgrade all the rest of firmwares.
                      Problem solved, many tanks to all of you.
                      VJ
                      • FRIDGEMAGNET
                        • Aug 2007
                        • 377
                        Thanks for the update glad to hear it went well.
                        • aivars
                          • 11
                          system SD card
                          Hi, the same problem
                          can I use for recovery a D101 5530 SD-Card:Copy:B-C3:Common (Model C3.5)
                          or only B234 5530 SD-Card Copy (Model C3)
                          this SD cards are the same, only containing a latest firmware ?
                          thank you
                          • max68
                            Re: MP9000 Firmware update problem
                            None of that worked
                            Tanks
                            VJ
                            You're a genius! Thank you very much!!
