Pro 5110S calling for Yellow cleaning unit.
  • copier tech
    • 8144
    [Misc] Pro 5110S calling for Yellow cleaning unit.
    Hi all,
    I have a 5110s that is calling for the yellow cleaning unit yet the PM counter has not been reached.
    I assume this has happened as the lube bar end sensor has been actuated?
    Machine is in a church so as you can imagine this machine is heavily relied upon now!
  • davel
    • Oct 2011
    • 1104
    Re: Pro 5110S calling for Yellow cleaning unit.
    Dont know but we carry rebuilt units to reduce downtime.
      • 37489
      The lube bat has most likely worn unevenly. Disconnect one lead from each of the lobe bar end sensor and either wrap it with electrical tape or shrink tubing. You will probably have to reset the counter for the lube bar. Be sure to order the parts to rebuild the cleaning station unless you enjoy replacing drums.
      • copier tech
        • 8144
        • copier tech
          • 8144
          Thanks for the tip this worked a treat had to do a manual new unit set after even though the unit was under PM life.
          Now hoping there is enough of the bar left or it could be an expensive mistake!!!
            • 37489
            I don't know about Ricoh-EU but with Ricoh-USA I could usually get parts in 2 days.
            • copier tech
              • 8144
              Yeah 2/3 days i'll be back on site to fit the lube bar, in fact I ordered the complete cleaning ass'y & 3 spare lube bars to keep on site.
