Ricoh MP 2554 shows copying forever
  • Riviera
    • Sep 2016
    • 66
  • rthonpm
    • Aug 2007
    • 2859
    Re: Ricoh MP 2554 shows copying forever
    Could also be a memory issue. Power the machine off, unplug it, and then turn the power button back on: this will flush out any residual charge left in the RAM and clear anything still in it. Also try re-seating the DIMMs.
    • mikadonovan
      • May 2008
      • 2931
      It's been a few years back, but I believe this used to occur on another model (I do not remember which one), and the fix was a HDD replacement.
      NEVER ASSUME ANYTHING
      • sandmanmac
        • 3983
        Agree Mika.
        That's the first thing I'd try too. My question is why has the poster apparently tried Nothing?!
        Disconnect the drive and see if basic functionality is restored. If so, replace HDD as suggested
        • skinnyb
          • Jul 2008
          • 291
          Hdd most likely. I agree.
          Sent from my LM-V405 using Tapatalk
          • Klydon
            • Mar 2009
            • 243
            Another in the 'look at the HDD' camp.
            • luca72
              • Oct 2017
              • 1791
              try to reset via sp "copier application" and/or boot the machine with hdd disconnected...to see wath happen.
              "I'll be back"
              • Gab
                • Aug 2015
                • 674
                Perhaps the start button is stuck
