Ricoh Mp C3002 duplex smears copy on 11X17 paper only
  • COPIERMAN
    • Jun 2009
    • 559
    ledger size or 11X17 paper staples paper single side it prints fine only when duplex it smears. work fine on letter or legal size paper. i try another fuser has same problem. Any suggestion would be helpful. thanks in advance. I do see there are pressure and heat adjustments in service mode but would think it would do same on all the different sizes
  • StephenB
    • Aug 2015
    • 244
    Re: Ricoh Mp C3002 duplex smears copy on 11X17 paper only
    My problems with smearing have always been fuser related, you are using OEM fuser and toner ?
    Then paper weight, try setting ( on driver) to a heavier type. You are using the correct driver ? do not use a universal or WSD driver
    Good luck
    • COPIERMAN
      • Jun 2009
      • 559
      yes on oem that is only thing we use on color copiers. We try thick 1 but had same problem.
      • fshead
        • 2376
        ITS probably the fuser film.or pressure roller.
        Did you ck the meter on the fuser unit?
        Do you have a spare to swap to see if it is that..
        I keep one mpc3002 and one mpc3003 on hand all the time..
        • COPIERMAN
          • Jun 2009
          • 559
          i already try swap fuser same problem
          • fshead
            • 2376
            srry i glanced the post.
            I would do a single copy and refeed it thru the bypass tray.
            If it still smears I would still think fuser,did you try heavier paper settings too?
            • Zaxxon
              • 608
              Please start you post with brand, model, problem.
                you mentioned:
                tried 2nd fuser.. same issue
                oem T&D
                never saw examples of defect
                life on PM parts?
                weight of paper?
                coated? rough?
                any errors in log?
                cleaned the machine?
                Zax could have hit something.. but what about 2nd side 'buckle'?
                is the smear at top or bottom?
                also I would make sure there is no loose toner in duplex path.. vac/wipe out no canned air.
                • StephenB
                  • Aug 2015
                  • 244
                  Just thought, the smear (only on 11x17) may be caused by a feed clutch, in the duplex feed sticking or over driving which could cause a buckle / smear.
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    It's the fuser motor. There was a mod about it.
                    Hit it.
                    • Imprestik
                      • Aug 2012
                      • 297
                      Its either the above or their is a bulletin on this about "cold offset" I think it was called.
                      fusing temps needed to be bumped up to a certain level
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        I remember there was a machine which had problems with small paper size.
                        Firmware was the solution.
                        But i'm not sure if it was the c3003.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          also check the paper transfer separation unit, is it broke on either side?
                          • Zeldaman
                            • Mar 2011
                            • 946
                            Hi there!
                            With SP 1-801-072 you can change fuserspeed ( +0,5% - +1,5%) install a new fusermotor AX060430.
                            Greetings...
                            • dhg
                              • May 2011
                              • 26
                              Originally posted by Zeldaman
                              Hi there!
                              Greetings...
                              look at the bulletin Number ( 030 ) under the mpc3003 D146, sounds like similar issue. There are some bit switches relating to toner that may need to be changed.
