Ricoh Mp C3002 duplex smears copy on 11X17 paper only
  • Brianneoe
    • May 2015
    • 322
    #16
    Re: Ricoh Mp C3002 duplex smears copy on 11X17 paper only
    Without looking at the bulletins mention..Did you clean the upper guide on the fuser entrance. It will collect toner and during double sided printing 11X17 the paper will come in contact with the non fused toner and leave marks. Just wipe the entrance guide to see if that is the case. Had this more as a issue than any fuser motor speed problem.
    • fshead
      • 2376
      #17
      That guide should be checked and "scraped clean" on every call.
      If NOT that caked toner can scratch the roller and cause jamming too.
      • Brianneoe
        • May 2015
        • 322
        #18
        Not that one..the entrance frame itself will collect toner on it. It will stay non fused and will leave marks until its wiped cleaned.
        • tonerhead
          • Sep 2009
          • 582
          #19
          It is fuser motor. Bulletin was issued on it.
          I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
          Especially when it comes to sex
          • anothertech
            • 1771
            #20
            What is the bulletin number?
            • tonerhead
              • Sep 2009
              • 582
              #21
              Sorry, not a bulletin. It is in global knowledge base. I had same problem. All paper works but 11x17 smears. I copied from global knowledge base and put on share drive. I think company wide we had about 3 machines with similar and replaced motors on all to fix. Here is link to share drive
              Smeared images occur on the trailing edge of the A3 paper.pdf - Google Drive
              Hope it helps.
