Technology
  • lee doo joon
    • Jun 2019
    • 7
    [Error Code] Technology
    Can someone help me mp c6502 error 442-00
    • 30550
    Re: Technology
    Mpc6502 .sc442-00
    • lee doo joon
      • Jun 2019
      • 7
      Re: Technology
      thank you but i have replaced the part like the picture you sent me but the error 442-00 still stays, is there any way you can help me?
      • anothertech
        • 1771
        Re: Technology
        Well Sir, I think you're going to need a Ricoh tech.
          • 37628
          Re: Technology
          Have you even tried to lookup the service code in the service manual? Or maybe used Goose's Guide?
            Re: Technology
            that's too much work.. easier just to come here give little info on what he has done/tried, then expect us to guide him step by step on the repair.
              • 37628
              Re: Technology
              Did you replace the motor with the new motor PN D1361212 specified in the bulletin or did you try replacing the pinion gear?
              • butcher
                • 48
                Re: Technology
                If you've already replaced that part, it could possibly be the belt lift HP sensor at the back of the ITB unit.Or the lift mechanism itself.
                The best way to check the lift motor unit that you replaced is to remove the ITB unit, reach in to the cavity and manually turn the coupling that drives the ITB lift mechanism. If it turns freely then it's faulty.
                The entire lift motor assembly part number is D1361025 should you need it.
