Mpc5000 vs mpc4500 toner pump ?
  • mrfuser
    • 1626
    Anyone know if the mpc5000 and mpc4500 pumps are the same?
  • 8T2
    • Aug 2015
    • 257
    Re: Mpc5000 vs mpc4500 toner pump ?
    Can't remember off the top of my head but if the drive gear on the pump is the same size it should work.
    Sent from my WAS-LX1 using Tapatalk
    • Hadster
      • Aug 2011
      • 264
      They are not the same.
      Sent from my LG-US998 using Tapatalk
        • 37628
        If I remember correctly, the only difference is possibly the length of the hose. Be sure to order the correct PN for the color toner you need a pump for. If your parts catalog does not list separate numbers, download the newest catalog. Ricoh quit shipping pump and hose separately years ago because of the tendency of old hoses clogging.
        • Hadster
          • Aug 2011
          • 264
          Frame on pumps are different. They will not be able to swap.
          • mrfuser
            • 1626
              • 37628
              From the pictures in the Replacement and Adjustment sections of both service manuals look very similar, in fact almost identical just cropped a little different. If you have one to try, do so. I know there were a couple of older models that we had to use newer model pumps on after Ricoh start bundling the pump and hose.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Yep...different sized casing.
                Doesn't work.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  I've tried and they physically don't fit.
                  • skinnyb
                    • Jul 2008
                    • 291
                    Same. The B223 pump only fits the older units.
                    Sent from my LM-V405 using Tapatalk
                    • tufbnme
                      • 493
                      I second or third that they are not interchangeable. The C5000 is physically bigger.
