SP5200DN
  • The_man
    • Jan 2016
    • 40
    [Error Code] SP5200DN
    Hi Ricoh SP5200 with SC530, SC532. SC534 in succession ie 1 second apart on error list have changed all fans works for a bit then random SC534 or SC530 done alot of prints 950K. Thinking psu or engine board!!!! Any thoughts?
    • 37533
    Re: SP5200DN
    Check for dirty/clogged vent filters.
    • The_man
      • Jan 2016
      • 40
      Re: SP5200DN
      Cheers will do going back monday with boards just in case though.
      • zed255
        How'd ya manage that?
        • 1024
        Re: SP5200DN
        I have had a few failed engine boards leading to fan related SC's, usually from the failure of the fan initially. I did have a more persistent one where the PSU needed to be replaced as well. The engine board failed a second time shortly after the fan and first replacement engine boards were installed. Overall this hasn't been a really common issuein my fleet.
        • anothertech
          • 1771
          Re: SP5200DN
          Have you reseated all of the connections from the fans all the way back to the board?
          • skinnyb
            • Jul 2008
            • 291
            Re: SP5200DN
            Same. Bad clogged fans lock up and back feed to the board. Have seen it not just on this model. Had a controller board fan on a MP C5501 blow a controller board once. I try to always hit the filters and fans with a vacuum at least every pm if possible.
            Sent from my LM-V405 using Tapatalk
            • The_man
              • Jan 2016
              • 40
              Re: SP5200DN
              Thanks for the reply's people given me food for thought, as all fans replaced will try engine board route and let you know what happened cheers.
              • fshead
                • 2376
                Re: SP5200DN
                i work on a lot of old shht and at 950k swoop in and upgrade.......make ur job easier...............even a used low meter unit
                I always acted like Norm ON THIS OLD HOUSE: trying to keep machine running forever but
                in the real world most customers are happy with 5 yrs and know it they ran it hard......
                OR just start running up boards and labor.............
                • The_man
                  • Jan 2016
                  • 40
                  Re: SP5200DN
                  Just an update seems to be stable now after fitting EGB so probs old fans have caused issues with EGB. Thanks
