Ricoh mpc6501 sc 336
  • levantin
    • Aug 2019
    • 26
    After running 3801-003, the error machine sc 336 looks for help
  • GIUBOSS
    • 1435
    Re: Ricoh mpc6501 sc 336
    Developer set error: K
    The value of Vcnt is set at the maximum or minimum setting when the TD sensor is initialized.
    • GIUBOSS
      • 1435
      did you replace only the black developer?
      • levantin
        • Aug 2019
        • 26
        show me how to handle it
        • GIUBOSS
          • 1435
          the sp setting values ​​are found in the birth certificate, then if the machine does not perform the initialization correctly, the sensor t could have a problem in the K unit. What operations have you performed before the error besides the 3801-003? did you replace something ??
          • levantin
            • Aug 2019
            • 26
            I have not done any thing. Is the td k error?
            • davel
              • Oct 2011
              • 1104
              If you ran the SP without first replacing developer correctly you have broken machine, call a tech that has experience with this machine or update the toner belching beast.
              • Zaxxon
                • 608
                Please start you post with brand, model, problem.
                  • 37489
                  Why did you run SP 3801-003? Had you just replaced the black developer?
                  • The_man
                    • Jan 2016
                    • 40
                    If you put new Dev in need to check dev fill set are all 1111 also dev initialize set 1111, if any other numbers other than 1 need to re initialize that dev, not supposed to but may get you out of a never ending problem, if this is ok do a pro con density via sp mode, worth a try
                    • Zaxxon
                      • 608
                      And make an effort emptying the development unit completely.
                      • The_man
                        • Jan 2016
                        • 40
                        Good,call but don't use a vac on it as sometimes you can damage TD sensor, new dev unit in that case as TD not available on it's own.
                          • 37489
                          Actually the sensor is available on its own. There is a usable part number on the label. What is not available is the two sided foam mounting tape.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Could also be id sensor within the transfer belt unit always gets dirty
                            Regards Mark
