sc 142
  • babu
    • Apr 2018
    • 19
    [Error Code] sc 142
    Hi guys I have a ricoh mp6002 giving me a code after start up sc142, I have replaced all the boards
    1. Image scanning Board
    2. PCB: SIOB
    3. PCB: BCU
    4. PCB:CNB :Assy
    5. Power supply unit: main
    6. PCB:PFB:Three way
    7. Exposure lamp
    8. Lamp stablizer
    9. Scanner motor
    Then again sc142, Now what should I do?
    Re: sc 142
    2. PCB: SIOB
    3. PCB: BCU
    4. PCB:CNB :Assy
    7. Exposure lamp
    8. Lamp stablizer
    9. Scanner motor
    sounds like you really don't know what part of the machine is kicking the SC code. Did you look it up in the service manual?
    You are taking the "shotgun" approach to troubleshooting. Very expensive way of going about it .
    • Zaxxon
      • 608
      Please start you post with brand, model, problem.
      • babu
        • Apr 2018
        • 19
        Re: sc 142
        The optics including white plate are cleaned but not solved.Then after followed the service manual and I checked each board but still not resolving......
          • 37444
          Re: sc 142
          Then the next step is to replace the lamp regulator board.
          • anothertech
            • 1766
            Re: sc 142
            The book lists in this order,
             Dirty exposure lamp or optics section
             SBU board defective
             SIOB defective
             IPU board defective
             BCU board defective
             Harnesses are disconnected
             Exposure lamp defective
             Lamp stabilizer defective
             Scanner motor defective
            Did you replace the IPU?
            Does the lamp come on?
            Check the scan harness to see if it's shorting
            HDD could be bad
            Are there any other sc codes stored?
            • Brianneoe
              • May 2015
              • 318
              Re: sc 142
              Just left of the CIS is a mylar strip that collects crap. Peel back the strip and clean the top and bottom. Don't remove it but clean both sides.
              Good luck
              • babu
                • Apr 2018
                • 19
                Re: sc 142
                Yes I did, Lamp moving and lamp on ,I Changed all PCB and HDD replaced but sc142 again
                • babu
                  • Apr 2018
                  • 19
                  Re: sc 142
                  MP6002 has no CIS, Exposser Lamp here in mp6002
                    • 37444
                    Re: sc 142
                    Guess again baby. MP 6002 comes with a one pass document feeder. You're thinking of the MP 6001.
                    • babu
                      • Apr 2018
                      • 19
                      Re: sc 142
                      I have disconnect the SADF connector then turn on the machine and sc142 displayed again
                      • Gab
                        • Aug 2015
                        • 671
                        Re: sc 142
                        The p[roblem is at exposure. First lubricate rails tec. Is scaner mooving smoothly?
                        What about sensor?
                        • keithxxiii
                          Just a tech
                          • Nov 2014
                          • 468
                          Re: sc 142
                          Could be a short circuit within the system. On a different machine, (MPC4501) i had these SC 1XX a couple of years back. I swapped most of the boards that are related to it in our workshop but couldn't fix. When I checked the service history, the last call was to replace the Transfer Assembly. Tech did not tighten the screw properly and was grounding the system. Had to tighten the screw and just like that, problem solved.
                          My 2 cents
                          Aye! Cut the crap
                          • Guvez06
                            • Nov 2024
                            • 1
                            What's the solution?
                              • 37444
                              Hey GRAVE ROBBER this thread was over five years old, dead and buried. Not a good start.
