Fuser temperature adjustment
  • AjitN
    • Mar 2009
    • 287
    [Misc] Fuser temperature adjustment
    All
    This is for MP C2004. I am bit confused regarding fuser temperature adjustment.
    I want to the reduce fuser temperature to meet customer's requirement (for some special paper).
    I do not want to play / take trials with Fuser SP settings (there are too many).
    Can anybody guide / suggest me which SP settings I should change.
    Thanks in advance.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Fuser temperature adjustment
    Can you not just set the paper type to thin paper so it lowers the temperature automatically? Why do they want the temperatures adjusting, does the media melt?
    Hit it.
    • FrohnB
      • Jul 2017
      • 1919
      SP 1-105-001 thru 148, is where you can set the Target Print Temps for the different thicknesses/types., but as suggested before, why not use a thin setting that will bump the temp down without having to "hard set" to a lower temp (which could cause issues going forward on other media).
      Omertà
        • 36911
        Scroll through SP-1-105 or print the SP Mode Data list SP 5-990-002 or export to an SD card SP 5-992-002. Pick the paper type/thickness that has the temperature value that you wish to use.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Best to only use oem toner and set paper type this should work
          Regards Mark
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            You can also they this I do when katun toner used
            Not oem toner
            mpc2003/4 to mpc 6003/4 series adjust
            3612-131-132-133-134 K.,C,M&Y
            SET ALL TO 600
            Regards Mark
