Can i convert a SOP machine back to NOP?
  • fshead
    • 2376
    HI
    I have a low meter MPC401SR that i want to pop a SOP panel on and remove that SOP from a high meter MPC401SR.
    Can i then convert that high meter SOP machine into a NOP once I swap op panels and change the FW,do all the SP modes that are listed in manual?
    thanks
    • 37556
    Re: Can i convert a SOP machine back to NOP?
    I believe so. You merely need to reverse the installation steps. Do the last step first and work backward to the first of the installation.
    • fshead
      • 2376
      thanks
      I have only used package FW on both NOP and SOP mpc401 that i placed.
      Regarding the engine and system FW for the mpc401 BOTH NOP and SOP versions ,can you tell me are they both the same prefix D190.....
      • Klydon
        • Mar 2009
        • 243
        I did not see a engine listing for the SOP version. System has a D191 prefix for both versions. (latest is 1.14 for SOP and 1.13 for the regular panel).
          • 37556
          Normally the engine firmware is the same for both.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Smart panels have different firmware
            Regards Mark
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Please see attachments if helps
              Regards Mark
              • fshead
                • 2376
                I found the mpc401 Z SOP romdata FW now I just need to get mpc401 NOP romdata FW..
                  • 37556
                  Only certain modules. Other modules are common to both panels.
