MP4054 developer initialization when replacing entire PCDU?
  • copyaction
    • Oct 2007
    • 991
    Is the initialization procedure different when replacing the entire PCDU then when just doing a developer change?
    thanks
  • copier tech
    • 8144
    Re: MP4054 developer initialization when replacing entire PCDU?
    thanks
    No, simply fit the PCDU initialisation is automatic.
    Do you have the service manual?
    PCDU Installation.pdf
    • copyaction
      • Oct 2007
      • 991
      [ATTACH]44670[/ATTACH]
      thank you for that, I did not have the manual.
      • copier tech
        • 8144
        FYI, it's a lot cheaper to rebuild the PCDU than replace the complete unit.
        I usually just replace the drum, blade, charge & cleaning rollers.
        Dev usually goes way past PM life.
        • copyaction
          • Oct 2007
          • 991
          • FrohnB
            • Jul 2017
            • 1919
            Omertà
            • Coptech
              worker drone
              • 460
              After you atart rebuilding the unit for exchange, Go into the end of the 3000 sp settings to manual new unit set and set all the appropriate items that have been replaced to a 1 before turning machine off and replacing unit. It will reset the counts and run the processes needed.
