Will a MPC2503 fit inside a MPC3503?
  • fshead
    • 2376
    OK.
    I know the mpc2503 is a cheap rate knockdown of the mpc3503.
    And having little experience with these I am curious if I can use any parts in a pinch.
    I was thinking of gutting a few cheap ones to use to rebuild drum and developer units with mpc3503
    drum,drum blades,lub bar etc etc...Anyone try this?
  • HitMan
    • Aug 2015
    • 170
    Re: Will a MPC2503 fit inside a MPC3503?
    You can swap the parts into the drum housing and it will work. Unsure of the dev unit though
    Sent from my SM-G930F using Tapatalk
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      No parts are not the same come on guys do the job properly mpc2003 2503 pcu's only do 60k that's why the PCU is cheaper drum blade may be the same
      Regards Mark
      • copier tech
        • 8144
        Originally posted by fshead
        OK.
        The 2503 & 3503 are PCU & DEV are completely different not a single part is the same (apart from the screws!)
        • skinnyb
          • Jul 2008
          • 291
          Truth. The pcu and dev on the 2503 is rated for WAY less and designed so. I order the charge roller assy for the 35 and up by itself. Makes the drum go longer unless the lube bar is used up.
          Sent from my LM-V405 using Tapatalk
          • fshead
            • 2376
            I know they are NOT EQUAL..
            but can you take a drum unit,a ITB UNIT OR FUSER UNIT and pop it in a mpc3003?
            I know the toner is the same although less.......
            I can find cheap mpc2503 and the gut them for parts so i rebuild the drum units with higher life parts etc etc.........
            • fshead
              • 2376
              as i dont see many mpc2503 s is it just the drum and the lub bar that will go at 60k?
                • 37489
                Most likely just the lube bar.
                • fshead
                  • 2376
                  i understand your reply i am trying to make mpc2503 EQUAL to mpc3003................
                  What i need to know like if i was on SURVIVOR what can i use on what i have.........
                  If the core is the same and i use high life drums,lub bars etc etc IS it worth it?
                  • copier tech
                    • 8144
                    There is no lube bar in the 20/25 series!
                    The drum cylinder is totally different the coating wears much faster than the 3/4/5/5 series.
                    • fshead
                      • 2376
                      ok thanks
                      i guess i will just have to pay up for some mpc3003 series to part out for drums/dev units and such.......
                      I dont like not having spares as free time to rebuild is never "free".
                      • copier tech
                        • 8144
                        ok thanks
                        Before you order the PCU first try replacing just the charge roller this is a lot cheaper & does improve the print quality.
                        • HitMan
                          • Aug 2015
                          • 170
                          Apologies but I'm wrong about the c2503 fitting the c3503. The drum I'm sure is totally different. I was able to get the c2504 drum parts to fit in a c3503.
                          • copier tech
                            • 8144
                            The C2504 PCU is the same as the C2503 & WILL NOT fit in a C3503!
                            • HitMan
                              • Aug 2015
                              • 170
                              Yeah you can strip out the parts and use them. The lube bar is about half the size of the higher speed machines as obviously they only last about 60k.
                              They are completely different part numbers and are not the same
