RICOH MP6001 542 AND 552
  • irokkas
    • Oct 2012
    • 18
    [Error Code] RICOH MP6001 542 AND 552
    Hello to everyone.At first there was a 542 code,so i check the thermostats and the thermistors and i notice that the lamp was dead.I changed the lamp and after that i had a 552 code.I changed the thermistors but the machine keeps giving me 552.I have change the hot roller and the firmwares are up to date.If anyone have a thought i would like to hear it.Thanks in advance for your responses.
  • GIUBOSS
    • 1385
    Re: RICOH MP6001 542 AND 552
    check the two thermostats near the thermistors, usually they must be lightly beaten to make them pick up again
    • fshead
      • 2360
      I would also change them if they are the old style wide ones..fairly cheap to buy.
      • irokkas
        • Oct 2012
        • 18
        change the thermostats and there was no result.Tried a fuser unit from another copier and it worked fine.I checked the new lamp and was faulty!!!Changed it and everything works fine.Thank you for your suggestions.
        • MIGUELMARCHENA
          • Feb 2018
          • 189
          well look at youthis has happened to me several times although not in this model,
          I have not worked it, and in some occasions, I have done everything, and nothing some things done check the current of the site, the shot is wrong.
          clear the fuser counters, all .
          5810 and 7807
          scrape contacts, all.I hope someone serves them
          Cheers
          • eccelobo
            • 113
            Sometimes there is low voltage and causes these codes. Check the wall tension.
