MPC 3001 - possible to increase memory?
  • mrwho
    Major Asshole!
    • 4299
    [Misc] MPC 3001 - possible to increase memory?
    Good morning folks.
    I have a customer whose machine is used to scan to multipage TIFF files. In order to be able to do that, as you might be aware, we had to disable gray-scale/colour compression.
    But now, as you might have guessed, customer complains that the machine is running out of memory when scanning.
    Is there any way of expanding the machine's ram? Or I better get ready to tell the customer that he must choose between the two?
    Thanks.
    Mascan42
    Ibid
  • ridgemill
    • Sep 2017
    • 190
    Re: MPC 3001 - possible to increase memory?
    If memory serves me right, I believe the MPC3502 uses the same RAM card, but instead of 512MB it is 1GB (G1786072). It might or might not make any difference.
    • FrohnB
      • Jul 2017
      • 1919
      Check in User Tools --> System settings --> File Transfer - and bump up your "Max Email Size" to as high as it will go.
      Also go into User Tools --> Scanner Features --> Send Settings - and turn Off Divide and Send - I think it's set to "Yes per max. email size".
      EDIT: If you're getting a message "Insufficient Memory at Destination Hard Disk" then you need to bump up the max email size on the email server side.
      Omertà
      • fshead
        • 2376
        Originally posted by mrwho
        Good morning folks.
        Thanks.
        Is he scanning to folder on PC or scanning to email?
        Did you check that the scan "gauge for a better choice of words" go back to 100%..
        might have unsent clutter in que
