MP 2555 enable print from memory device
  • TalksToToads
    • Feb 2020
    • 7
    I'm trying to use the "print from memory device" feature on a Ricoh MP 2555, and I keep getting the error "because of the current settings, printing of files on the memory storage device is not available". I have administrator privileges (all types). When logged in as administrator it says " you do not have the privileges to use this" or something like that. This seems to be tied to something unrelated to authentication. I've tried authentication off across the board, and basic authentication on, logged in as a user with all privileges. The memory card reader and USB are enabled in the screen settings, and I tried both authentication settings on that end for the app. I must be missing something here, any help would be greatly appreciated.
    Sent from my SM-A205U using Tapatalk
    • 37048
    Re: MP 2555 enable print from memory device
    For one thing, when you ware logged in as Administrator the only thing you have privileges to use is User Tools. Administrator does not have privileges to use copy, scan, fax or any other machine function. Never has, never will. Administrator is for administrating the machine not operating.
    • TalksToToads
      • Feb 2020
      • 7
      Yes, I remember reading that in the manual but like I said it doesn't work under a user or with authentication off either.
        • 37048
        Check Scanner SP 1013 Multi Media Func. It must be set to 1.
        • TalksToToads
          • Feb 2020
          • 7
          I will check that tomorrow, thanks!
          • Dan G
            • Nov 2014
            • 56
            [QUOTE=TalksToToads;1247116]Hi,
            Is it disabled in User tools?
            I also had a machine that would not recognize memory devices -diff than your issue but SP5801-18 was the cure for that
            • TalksToToads
              • Feb 2020
              • 7
              How do I get to service mode?
                • 37048
                Hire a trained and qualified Ricoh tech.
                • FrohnB
                  • Jul 2017
                  • 1919
                  Has nothing to do with any authentication settings.
                  Check "Printer SP 1-110 Media Print Device setting" should be "1". Just tried it on a machine in the shop by turning it to "0" and get your exact same message when I try to select "Print from device" from the app.
                  Also, it makes "Print from mem. storage device" disappear from the classic Printer screen. <-- Easiest way to check if it's disabled in Printer SP.
                  Omertà
                  • TalksToToads
                    • Feb 2020
                    • 7
                    Ok, here's how I fixed it. I popped off the small cover on the left side of the screen, held down the bottom two buttons there and pressed "check status". This brought up a keypad at which I pressed reset, entered the apparently top secret code, then held clear. Now in service mode I navigated to the Printer SP-110 setting mentioned by FrohnB, pressed 1 #, then rebooted. Fixed!
                      • 37048
                      Ok, here's how I fixed it. I popped off the small cover on the left side of the screen, held down the bottom two buttons there and pressed "check status". This brought up a keypad at which I pressed reset ****** then held clear. Now in service mode I navigated to the Printer SP-110 setting mentioned by FrohnB, pressed 1 #, then rebooted. Fixed!
                      Placing that SP entry code in open text in a public post is a violation of General Rule 5. Discussion of illegal activities such as software and music piracy and other intellectual property violations are not allowed. That code is propriety Ricoh intelligent property. Keep it up and you are going to lose that green card. You still have time to edit the post to delete it.
                      • anothertech
                        • 1757
                        Ok, here's how I fixed it. Now in service mode I navigated to the Printer SP-110 setting mentioned by FrohnB, pressed 1 #, then rebooted. Fixed!
                        Could you edit this post to remove the service mode access information please?
                        • TalksToToads
                          • Feb 2020
                          • 7
                          ok, I removed it but I found it on this very forum. Ricoh MP 2554
                            • 37048
                            Apparently you failed to read the reply I made to that post. "I believe that Ricoh changed the key sequence and left the new sequence out of the service documentation in order to keep untrained individuals from entering SP mode and causing problems."
                            • TalksToToads
                              • Feb 2020
                              • 7
                              I did indeed read that, but that doesn't change the fact that there is another reply in that thread with the correct sequence.
