mpc 2004 fusıng sleeve
  • usta
    • Oct 2013
    • 44
    In the paper-paper shooting mode of the mpc 2004 copier, the upper roll of the oven is constantly deformed in 15-20,000 copies. anybody have a suggestion? thank you
    • 37533
    Re: mpc 2004 fusıng sleeve
    paper-paper shooting mode ????
    upper roll of the oven ????
    If you don't know the proper terminology, look it up.
      wow! never seen it described as such in ANY manual..
      • GIUBOSS
        • 1436
        What type of paper are they using? If you always use card stock, the fusing unit will not last long. For certain weights there are specific settings. With a small amount of light thermal grease applied to the bushings of the sleeve helps.
        • Polarbear
          • Feb 2012
          • 1070
          Me thinks Google Translate let this chap down badly....
          Press the GREEN button!!
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Only fit oem parts when fitting a sleeve assy best to fit the pressure roller at the same time. Try not to use film only from China
            Regards Mark
            • Polarbear
              • Feb 2012
              • 1070
              +1
              The sleeves are a PITA to fit and sometimes kink on first startup!
