Mp 4002 printing light in parts that have a large toner area.
  • n.davison
    • Nov 2019
    • 4
    I am having a weird print quality issue where I can't narrow down where the problem is.
    Imgur: The magic of the Internet
    When printing parts that has a large surface area of toner, it looks like that, but text looks just fine. The bottom of the photos is the lead edge and the top is the trail edge. The edges of the squares on that are perfectly dark, as well as the lead and trial edge, which I don't really understand why.
    The PCDU had a full PM 16k prints ago, and the transfer belt was also replaced. I've tried cleaning the laser glass, cleaning the charge roller, and replacing the developer. I've also checked all the electrical connections inside the PCDU.
    I basically don't know what to try next apart from replacing the whole PCDU, which I'd rather not have to do.
  • skynetto
    • Sep 2012
    • 257
    Re: Mp 4002 printing light in parts that have a large toner area.
    You said you changed developer. Have you used the correct procedure for initializing it?
    Bias has to set up to default and 2 or 3 more corrections.
    Have you used a piece of paper to block toner dumping un PCDU during developer initialization?
    Have you cleaned the mag roller properly?
    These machines are a beast with proper maintenance. So something is wrong in what you did.
    • n.davison
      • Nov 2019
      • 4
      Yes, I ran 2801 to initialize it, and I did use a piece of paper to block toner from dumping into the developer. The mag roller was still clean from when the previous technician did the PM, but I went ahead and cleaned it thoroughly anyways.
      There was no change in the print quality from before or after I changed the developer.
        • 37628
        Are you using Genuine Ricoh toner and developer? Developer roller coating is bad enough without making it worse with after market supplies.
        Did you run SP3001-002 after replacing the drum? Check the value of SP3001-001, P Sensor Setting. It should be close to the default value of 13. If after running SP3001-002 it is still off, the ID sensor may be dirty or damaged. Clean the sensor only with a soft cotton cloth moistened slightly with water. Use of anything other than a cotton cloth can cause static that will result in toner being attracted to the surface making it dirty. Use of window cleaner can leave a film. Use of alcohol or other solvent will etch the surface of the sensor requiring replacement. After cleaning or replacing the ID sensor run SP-3001-002.
        • n.davison
          • Nov 2019
          • 4
          Developer is Genuine Ricoh, and the customer ordered 2 toner bottles from us for that machines back in October, so it's unlikely they bought third party toner, but ill double check next time I go out there.
          I did not replace the drum, another tech did a couple months ago, and I don't know if ran SP3001-002 or not. I'm going to be going out there again tomorrow with a PCDU from a scrap machine, but i'll check SP3001 before replacing it.
          Thanks for the suggestion.
            • 37628
            What happens when the ID sensor is dirty is the ID patch looks darker than it actually is. This causes the machine to think it is properly toned when in fact it is under toned.
            • sandmanmac
              • 3990
              At this point, I'd suggest removing the laser unit and cleaning the internal optics
              • keithxxiii
                Just a tech
                • Nov 2014
                • 471
                Mind if you share the SP table?
                Aye! Cut the crap
                • zed255
                  How'd ya manage that?
                  • 1024
                  The fill is weak but there is a dark edge. I have seen this when the transfer assembly leads have been mixed up, the two connectors that connect to the belt assembly from the cleaning assembly. Make sure the bias leads are positioned correctly and if not sure there is no harm is swapping them for a test.
                  • luca72
                    • Oct 2017
                    • 1792
                    if the pcdu components have 16k prints, and you have performed the whole procedure correctly .... go like a sniper! ... open the laserbox, and clean all the mirrors and glasses you see...ahh i forgot..clean the slide of the ID sensor, i tell you because many do not.
                    "I'll be back"
                    • n.davison
                      • Nov 2019
                      • 4
                      This ended up being the solution, thank you!
                      • zed255
                        • 1024
                        Thanks for popping back in for an update. That really helps complete a thread and far too few seem to come back and post the final solution.
