Wireless printing (im series)
  • sharpmind
    • Sep 2009
    • 478
    Can you guide me on how to configure wireless printing/scanning using the WIFI features of the machine?(SCREEN FEATURES--WIFI--ON). For example, the client has wireless router which is 15 meters away from the printer. I know the basic procedure of scan to folder configuration. How can I make the IP address static if the printer is connected wirelessly.
  • zed255
    How'd ya manage that?
    • 1024
    Re: Wireless printing (im series)
    The panel Wi-Fi does not replace the normal Wi-Fi option for the controller. It is mostly just a data connection for the SOP to use so as far as I'm aware you will not get full functionality via that connection. I have heard printing can work but that is all unless someone else with more knowledge can correct me.
    • mikadonovan
      • May 2008
      • 2931
      That's probably not going to work, especially for scanning, and maybe not for printing either. I have a spc360dnw printer I used as a test for the built in " "LightOn" WIFI. It worked for printing, but it was only 8 feet from the router and the printer signal strength was only at 72%. At 15 meters it may not work at all. Forget the weak internal WIFI and just buy a WIFI extender for $50. They work great. I believe the built in WIFI is for people to walk up to the machine and connect with WIFI direct without having to contact the IT guy to manually add your device (phone or tablet) to the network.
      NEVER ASSUME ANYTHING
        • 37653
        If you wish to print to, scan from and whatever other functions are available to mobile devices, download the current Ricoh Ap and go for it. If you want to access it by your local WiFi network, do what Mika suggests.
        • sharpmind
          • Sep 2009
          • 478
          If the printer and the laptop can connect to the access point, how can I know the acquired IP address of the printer? I checked every setting but I cannot find the acquired IP of the printer.
            • 37653
            I retired before the IM series but it used to be in User Tools - System Settings - Interface. Then click Print Interface Settings.
            • zed255
              • 1024
              Have you selected DirectConnect (group mode if I recall) on the interface tab in user tools to select the panel Wi-Fi connection?
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                wifi range extender is FAR less painful a solution...just saying
                • skinnyb
                  • Jul 2008
                  • 291
                  Truth. And works better / more reliable.
                  Sent from my LM-V405 using Tapatalk
                  • Kimi
                    • Feb 2018
                    • 105
                    You can find the IP or specify DHCP/static with the below setting
                    panel settings > wifi > select network > select show advanced options
                    • General Copiers
                      • Feb 2020
                      • 27
                      Hi. The wifi you are talking about is that of the operation panel.
                      It practically works "well" only when the panel is turned on. When the machine goes into standby, the wifi practically is off.
                      In fact, there is the "wireless interface" option, but given its cost, a wifi extender is the best solution.
                      • sharpmind
                        • Sep 2009
                        • 478
                        Machine is already connected to the access point. I try to ping the IP address assigned but the TTL=64ms. The web image monitor is not showing when using the browser. Using the Ricoh connector, machine is detected but not able to print. The green light just blinked then gone. there is no user authentication set to the machine. Any ideas where the problem is?
                          • 37653
                          Just because there are no users setup, do not assume that user authentication is not enabled for the print function. Also make sure that IEEE 802.11x is not turned ON. It is only for for Ricoh's over priced internal wireless card and for high end authentication like Kerberos.
                          • sharpmind
                            • Sep 2009
                            • 478
                            I bring my own wireless router and put it beside the machine.
                            Steps i have done...
                            enabled the wifi features of the machine
                            user tools>screen features> interface settings>wifi network.
                            Connect to the WIFI
                            search the SSID (Homebroadband) and connect
                            Set the static IP address (192.168.1.5) in advanced options.
                            Can I ping the IP address? Yes, TTL=64
                            MY android mobile is also connected to Homebroadband.
                            Now, I want to print through Ricoh connnector.
                            Open the app>add machine>add by IP address (192.168.1.5)
                            SEARCHING FAILED.
                            Am i doing the right procedure in configuring wireless printing?Is there anything that I have missed?
                            • General Copiers
                              • Feb 2020
                              • 27
                              Try using the app RICOH Smart Device Print&Scan
