Wireless printing (im series)
  • UNICORNico
    • May 2018
    • 308
    #16
    Re: Wireless printing (im series)
    Originally posted by sharpmind
    I bring my own wireless router and put it beside the machine.
    Steps i have done...
    enabled the wifi features of the machine
    user tools>screen features> interface settings>wifi network.
    Connect to the WIFI
    search the SSID (Homebroadband) and connect
    Set the static IP address (192.168.1.5) in advanced options.
    Can I ping the IP address? Yes, TTL=64
    MY android mobile is also connected to Homebroadband.
    Now, I want to print through Ricoh connnector.
    Open the app>add machine>add by IP address (192.168.1.5)
    SEARCHING FAILED.
    Am i doing the right procedure in configuring wireless printing?Is there anything that I have missed?
    In my experience, the wifi adapter that incorporates the "IM" (or earlier) models have a very unoptimized and unoptimized configuration.
    As one colleague has said before, you'd better book that connection for mobile device use using the APP provided by RICOH.
    I usually recommend to all customers, that the device pays more efficiently if it has wired connection, towards the router directly.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • kplow1986
      • Nov 2013
      • 41
      #17
      Connect to the WIFI
      SEARCHING FAILED.
      ricoh stupid wifi design.....ricoh SOP wifi print and scan only work with direct connect, and it wont print or scan through other wifi connection.
      if u want to print throught ricoh connector or older version like ricoh smartprint scan, use wifi extender or AP and connect to machine LAN using cable, just work like wifi copier.
      • mikadonovan
        • May 2008
        • 2931
        #18
        True story.
        NEVER ASSUME ANYTHING
