Ricoh cp320dn
  • Cdenzy
    • Feb 2020
    • 2
    Ricoh cp320dn
    Went to a call today for a ricoh cp320dn, the issue is that it thinks there is a jam and is giving a error message to open the front cover and remove paper. I looked through this machine for about an hour and saw nothing, im not to familiar with thie model, so if anyone has ever seen this or has any suggestions feel free to reply, thanks.
    Re: Ricoh cp320dn
    Originally posted by Cdenzy
    Went to a call today for a ricoh cp320dn, the issue is that it thinks there is a jam and is giving a error message to open the front cover and remove paper. I looked through this machine for about an hour and saw nothing, i'm not to familiar with this model, so if anyone has ever seen this or has any suggestions feel free to reply, thanks.
    1) get a service manual
    2) RTFM
    3) run the sensor tests
    4) more than likely it is a stuck sensor
    5) print out the error log... work from newest to oldest logged errors.
    6) 'look thru the machine for an hour' did you wiggle any sensor.. pull out and drums etc?
    7) pull out paper trays see if any paper is crushed into the sensor cluster to the tray switches.
    my bet sensor stuck interanlly
    this is pretty much "Copiers 101"
    • GIUBOSS
      • 1385
      Re: Ricoh cp320dn
      sometimes the oscillating sensor is located inside the duplex located in the front door
