MP 7503 poor mage density
  • Marwanalhajbi
    • Jul 2018
    • 72
    i have uneven density on printed paper,on left side lighter than the right side,any suggestion?can i increase the bias as in mp 2501,what the SP mode helps with that??
    thanks
    • 37533
    Re: MP 7503 poor mage density
    A couple of potential problems.
    1. The MP 7503 is not level front to back. This causes uneven developer distribution. Use a bubble level and adjust the leveler.
    2. You have dust or toner on the laser shield glass. Take it out and clean it.
      +1 to Slim's suggestions
      • Gab
        • Aug 2015
        • 671
        clean charge roller
          • 37533
          Originally posted by Gab
          clean charge roller
          MP 7503 is a Martini series machine. It uses a charge corona.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            thanks
            Would be helpful to see some samples
            Regards Mark
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Let's also say one of the best ricoh series copier ever made and still is
              Regards Mark
                • 37533
                The biggest problem I ever had with any of them keeping the ID sensor clean. There were 2 different part numbers for the drum cleaning brush. On some one worked better than the other. And of course the one-way gears on the paper feed units.
                • eccelobo
                  • 113
                  But why they changed the transfer belt functioning? It lasts less than before!
