IM C300
  • Roger67
    • Nov 2013
    • 84
    #16
    Re: IM C300
    Thanks for the info.
    I have a new instal that is very faint on all colours.
    Did you remove the laser to clean, is this engine like the 305/306/307 range?
    Hello,
    Yes,first i liked to change the 2 Laser-Units to see,if the Problems changed from one to the other side,then when i saw how dirty
    the laser on the right side was ( MGT / BLK ) i only cleaned it,and the Problem was solved.
    Cheers
    Roger
    • ridgerunner
      • Nov 2019
      • 1
      #17
      Re: IM C300
      Good catch on the fingerprint!
      On all machines with ITB belt units there is a transfer roller under the belt at each drum. In shipping at one end of a transfer roller a spring can pop off and cause voids at that end for that color.
