IM C300
  • Roger67
    • Nov 2013
    • 84
    IM C300
    Hi Folks,
    i have a brand new IM C300 which comes with the following prints:
    Color Registration Adj. is not possible also the music - adj in the Tech Mode.
    Anybody has ever seen something ?
    Cheers
    Roger
  • guitar9199
    • Sep 2016
    • 1100
    Re: IM C300
    Somewhere in SP mode you should be able to find "Force Line Adjust". I can't remember off the top of my head where it is, or if it's in regular or special SP mode. If you can't find it, you can always pull out the "Birth Certificate" and manually key in those settings.
      • 37605
      Re: IM C300
      That void in the magenta might be your problem. It appears to be roughly where one of the ID sensor assembly elements is. Things to check are laser shield glass, dirty magenta doctor blade or laser shutter. As long as that void is there, process cannot see the magenta patches used for color registration. Once that void is corrected and power is cycled, the color alignment might self correct.
      • General Copiers
        • Feb 2020
        • 27
        • JayPaul
          • Oct 2012
          • 305
          Re: IM C300
          Yeh I second that, you have to clear the magenta void first before doing anything. Very annoying to have to mess around with stuff on a machine fresh out the box, if there is a problem with dev, either sort it out or warranty it depending on your available time (or curiosity on a new machine). Could be some on laser glass etc so worth cleaning. Then after sorting out colour move onto colour registration, upon failuer try forced line adjust SP 2-111-XXX. I think you are meant to do in reverse order D, C, B, A but I would definitely check on that first because I hear different variations from different people.
          Also worth noting on these machines is that the fuser fan is very loud naturally and runs constantly while machine is not in sleep mode. In a quiet office I would suggest putting on maybe 5 minute sleep timer or something.
          My only IMC 300 had a call out because they said it was running so loud, when I got there they said it randomly just didn't go to sleep for hours despite nobody using it and no slow print spools. It has a new package firmware out last week, which you should put on. It didn't have anything in there relating to power saving system but maybe it fixes that annoying little glitch.
            • 37605
            Re: IM C300
            Will fail every time until the magenta void is corrected.
            • copier tech
              • 8205
              Re: IM C300
              Originally posted by Roger67
              Hi Folks,
              [ATTACH=CONFIG]44953[/ATTACH]
              Cheers
              Roger
              From your sample looks like you have an issue with the magenta PCDU.
              I would take out all the PCDU & transfer units check they all turn freely my guess is one is seized/jumping when driven.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Re: IM C300
                Never seen brand new machine do this if this new out of a box doa it. get a replacement. Or has someone done foll nvram clear?
                Regards Mark
                • Roger67
                  • Nov 2013
                  • 84
                  Re: IM C300
                  Hi Folks,
                  i have THE aswer for this Problem.
                  Take a look at the picture you can clearly seen a Finger Print on the Glas of the Magenta - Laser !
                  This FingerPrint was the reasen of the problem.
                  Now,i need to checkout,from which friendly Workers of Ricoh this Print comes from !
                  LoL.
                  Cheers
                  Roger
                  • davel
                    • Oct 2011
                    • 1108
                    Re: IM C300
                    Good find.
                    • luca72
                      • Oct 2017
                      • 1791
                      Re: IM C300
                      Hi Folks,
                      LoL.
                      [ATTACH=CONFIG]44966[/ATTACH]
                      Cheers
                      Roger
                      so you solved by cleaning that footprint?I had a similar problem on another model that went out of color registration and was a hard pcdu to turn.now you can make mac tylor of c.s.i ny, and make him lay off the worker ricoh
                      "I'll be back"
                      • tjvincent
                        • 280
                        Re: IM C300
                        That void is supposed to be there on the ACC pattern, has anyone not worked on the IM C4500 series ?
                        • copier tech
                          • 8205
                          Re: IM C300
                          Hi Folks,
                          LoL.
                          Cheers
                          Roger
                          Thanks for the info.
                          I have a new instal that is very faint on all colours.
                          Did you remove the laser to clean, is this engine like the 305/306/307 range?
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Re: IM C300
                            Hi Folks,
                            LoL.
                            Cheers
                            Roger
                            Great find well done
                            Regards Mark
                            • copier tech
                              • 8205
                              Re: IM C300
                              The void across magenta only slim was referring too.
