IS the mp305+ any good?
  • fshead
    • 2376
    hi
    i saw some odd units yesterday when picking up from my lease return warehouse.
    RICOH MP305 PLUS..
    Are they worth moving or another headache design?
    thanks
  • anothertech
    • 1768
    Re: IS the mp305+ any good?
    I've had about ten units out for about a year now, running good so far. From what I read on the forums, a lot of guys don't like them. For me, so far so good.
    • fshead
      • 2376
      THANKS
      IS it like a mp301 inside or some new design?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Originally posted by fshead
        hi
        RICOH MP305 PLUS..
        thanks
        Hi fshead
        Not as good as mp301
        The mp 305 is New design look after loads mp301 much better only good thing with mp305 is smart panel
        Regards Mark
        • anothertech
          • 1768
          MP305 PSG.pdf
          New design, different that anything else.
          • Klydon
            • Mar 2009
            • 243
            I have a few of these and have worked on them some.
            Very compact machine that looks like it would be difficult to dig into. Most of the issues I have run into involve curling paper and/or jamming. Doing the standard Ricoh black and white maneuver of turning the fuser temp down by 5 helps a lot. (IMO, I feel Ricoh black and whites over history run a little hot, so turning them down some doesn't hurt and they still fuse well, etc. It certainly helps with paper curl).
            The feeder is very light weight and should likely be avoided by customers that want to do a lot of scanning.
            • JayPaul
              • Oct 2012
              • 305
              It's more a machine that a customer wants, if they want to print/copy onto A3 but want a smaller desktop size machine. Welcome 305 +
              I only have 2 out and haven't had any problems I don't think but that could be luck or because they are in low volume offices. I honestly couldn't say if they are good or bad yet.
              • fshead
                • 2376
                thanks
                i gotta pick up a couple on my next pickup from warehouse..
                • Coptech
                  worker drone
                  • 460
                  In the training, it shows published life expectancy under 200K. They get put in places where people run much more than that on them.
                  • anothertech
                    • 1768
                    That is a sales problem, The Product Support Guide says 2000 copies a month, at that rate the machine should last 8 years. Any machine place outside the Ricoh volume guidelines is going to have a shorter lifespan time wise.
                    • fshead
                      • 2376
                      so it looks like 9k for toner and 120k for drum,feed roller and fuser rollers..
                      not so bad.......ARE YOU SEEING THESE YIELDS?
                      • sandmanmac
                        • 3981
                        Hey Andy.
                        PCU is actually rated at 60K
                        I can't really add anything else to the discussion.
                        I've only got one, and I use it at home right now
                        Like some others, I can't really talk about overall performance. Mine only has 7K on it.
                        I bought it because I liked the idea of a small footprint machine for someone that didn't have a huge need for 11"x 17" paper but wanted the ability from time to time, and also can scan ledger size paper.
                        Keep in mind it only runs ledger size from the bypass.
                        For the purpose it's designed for, it seems like a pretty solid little box to me
                        • fshead
                          • 2376
                          Originally posted by sandmanmac
                          Hey Andy.
                          HEY SANDY THANKS
                          I didnt really even get a good look at the machine but thought the design looked modern and sleek.
                          DID you connect the SOP to your phone and if so was it easy?
                          I am starting to find it harder to get mpc401 machines which i would sell and service any day of the week.......
                          • sandmanmac
                            • 3981
                            HEY SANDY THANKS
                            You mean with the Ricoh connector app?
                            Sure. Piece of cake to connect any device - even the old ones. I even have an SP C430 in my home office connected to the app.
                            I usually just add them manually with the search feature.
                            Honestly, for me phone/ tablet apps for printing are just a novelty - or at least only useful for someone that doesn't have access to a PC or laptop already connected to the device. They're way more tedious to use imo.
                            • fshead
                              • 2376
                              thanks SANDY..
                              I have to download that ricoh app and try to connect my SOP panel machines to get the hang of it....
                              I have some clients that never put down their phones and need to print/scan via phone...kinda sad
