MPC305
  • The_man
    • Jan 2016
    • 40
    [Error Code] MPC305
    Hi colleague of mine has MPC 305 with SC541. Has replaced 3 thermistors and thermopile, works for approx 10 pages then calls same code, cannot think of anything else on fuser that would cause this , maybe PSU?
  • FrohnB
    • Jul 2017
    • 1919
    Re: MPC305
    What's the PM counter for the fusing unit? I think they're only good for like 90 - 120k prints.
    It's probably the fusing sleeve. Does it make any noises when warming up or idling? Like a "crinkling sound" or bad knocking?
    Omertà
    • fshead
      • 2376
      Re: MPC305
      No. TypeDetails (Symptom, Possible Cause, Troubleshooting Procedures)541AHeating roller thermopile errorwithin the prescribed time for 10 consecutive times.Defective heating roller thermopileDefective thermopile1. Check if the heating roller thermopile is firmly connected.2. Replace the heating roller thermopile
      DOES THE COPY FUSE WELL?
      • The_man
        • Jan 2016
        • 40
        Re: MPC305
        Hi me thinks it could be the sleeve also as have not been to it but checked out parts manual, good shout cheers i will let him know Thanks.
        • fshead
          • 2376
          Re: MPC305
          If needing a low meter fuser or boards let me know as i have two that i will be parting out due to not wanting to do the toner mod.
          • The_man
            • Jan 2016
            • 40
            Re: MPC305
            Hi yes it fuses ok just calls Sc code after approx 10 copies we think it may be sleeve, but thanks for the info.
            • ridgemill
              • Sep 2017
              • 190
              Re: MPC305
              Most of the time it is usually a blown thermal fuse, broken lamp, damaged thermistor, or torn fusing belt, that causes this code.
              The fusing units are cheap to replace as a whole unit.
              • fshead
                • 2376
                Re: MPC305
                NO...
                MACHINE would not come to ready with blown lamp or fuse...
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Re: MPC305
                  In my experience with these delightful boxes, SC541 is usually the side door, the hooks that lock it in place screw onto a shaft that twists, stopping the door closing correctly. You'll notice the back side of the door doesn't sit flush against the machine. You'll need to replace that shaft, the hooks and the H-frame that the PTR sits in.
                  Hit it.
                  • Khumz
                    • Feb 2020
                    • 63
                    Re: Ricoh MP2553SP error code SC554-00
                    I sorry to come up with another problem instead of a solution. I have Ricoh MP2553SP which comes up with error code SC554-00. I replaced thermistors and a heat roller. When i try to run reset SP mode it kicks me out before i finish punching code "clear/mode,107,stop'. Instead it displays something about jobs to be suspended. When its displaying the error code SC554-00 if i try to access SP mode clear mode, 107 and stop keys dont respond.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      That's the wrong sp service code for this machine sc554 is very common all engineers should know this try looking in SM and replacing sleeve and reset fuse
                      Regards Mark
                      • The_man
                        • Jan 2016
                        • 40
                        Re: MPC305
                        That's interesting TM I will pass this on cheers for that.
                          • 37532
                          Re: MPC305
                          NO...
                          It can if it is the pressure roller thermostat or lamp.
