Ricoh MP2553SP SC554-00 ERROR CODE
  • Khumz
    • Feb 2020
    • 63
    I have this Ricoh MP2553SP that comes up with error code SC554-00. I changed thermistors and heat roller but the problem persist. It does not allow me to access SP mode. I have tried several SP mode access codes still no luck. Once it displays the error code keypad freezes. I want to reset fuser please help.
    • 37489
    Re: Ricoh MP2553SP SC554-00 ERROR CODE
    Some things to try:
    1. Power the 2553 on with the door open. If it is the code that is keeping you from entering SP mode, that should allow you to get in.
    2. Check that service access is not turned off in User Tools.
    3. If JAVA is installed and set to start up it can inhibit access to SP mode and most User Tools options until JAVA finishes loading. Normally 5 to 10 minutes.
    4. Someone may have changed the SP access code. Try using the old three digit code twice, i.e. abcabc.
    5. Last case scenario is to enter Factory SP and run SP 5810 from there.
    • Khumz
      • Feb 2020
      • 63
      Some things to try:
      1)Which door are you talking about?
      2) I can see services in user tools. Unless if i m not doing something right. Which code give access to User Tools?
      3) Which old three digital codes ?
      4) How do enter Factory SP
      • anothertech
        • 1769
        I figured that was going to be the case. It's time to call your Ricoh tech, and please don't say that you are the Ricoh tech.
          • 37489
          You are not a qualified Ricoh customer engineer.
          Any of the doors on the main frame.
          The User Tools button.
          If you were a qualified Ricoh customer engineer you would know.
          • Khumz
            • Feb 2020
            • 63
            [QUOTE=slimslob;1317701]You are not a qualified Ricoh customer engineer.
            Slimslob............
            Actually i had done most of all these technics without success so i thought i m get it wrong some how that is why i wanted more clarification. Anywhere thanks though i managed to figure out where i was getting it wrong. Yes i m not Ricoh guy but i have done quite a lot Ricoh machines. Thank you all.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              [QUOTE=Khumz;1317760]
              Best to call a ricoh Service engineer he would have this done in no time
              Regards Mark
