toner pump replacement lost screw mp c3500
  • bflorin
    • May 2019
    • 1
    My arm pulled the damn sheet of paper out during a k toner pump replacement on a mp c3500. Screw dropped right down the back slot at the gears. Whats the best approach at recovering this?
    Thanks!
    Blake
    • 37533
    Re: toner pump replacement lost screw mp c3500
    Unless it kicked through one the opening in the back frame, the first thing I would do is to pull out both paper trays and see if it ended up in back of them. If it kicked through, worse case scenario is that it ended up in the PSU. I have had them go all the way down to the bottom of the paper bank.
    Next time use a magnetic nutdriver and place the screws outside the machine.
    • copier tech
      • 8174
      Thanks!
      Blake
      On this old box turn the machine back on most likely its fallen into a void not causing an issue.
      Worst case BANG but its an old 3500 so no real issue!
      • dave w
        • Jun 2015
        • 230
        Yes the dam screws jumping ship into the back on the machine
        even with a magnetic driver it still happends.
        Its happened to me a few times when removing the Toner hoppers, once they jump ship you have two options.
        1 .. turn it upside down and shake the life out of it, you may get lucky
        2 .. turn on the machine and you may find all is fine.
        happy hunting
        Dave
        • fshead
          • 2376
          poke around with a long magnetic tool.
          or turn in on stay near on/off switch in case of grinding..........
          i d be more concerned if touches any kind of brd or such.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Thanks!
            Blake
            Get your self a 5.5mm magnetic nut driver. And of course all good engineers carry a couple of snap-ons your tools I feel should always be the best quality. {Buy cheap pay twice}
            Regards Mark
              • 37533
              Screws do fall off of a magnetized screw driver. I have never had one fall off a 5.5mm magnetic nut driver. Used to be able to order good ones from Ricoh.
              • mikadonovan
                • May 2008
                • 2931
                Thanks!
                Blake
                I have replaced a ton of toner pumps over the years and have lost maybe a dozen screws in the process. I never had any issues with just getting another screw. Fire it up and check the operation, you may be just fine.
                NEVER ASSUME ANYTHING
