ricoh Aficio MP C4502
  • printlessguy
    • Sep 2015
    • 63
    Hello All I am pretty sure after reading a bunch of thread and also seeing that around december 13 scanning stopped working its an issue with windows 10 and the firmware. here is a pic of the current version on the machine
    does anyone have the newer firmware and willing to trade or something to help me resolve this issue? thanks
    asking for my boss. I've been a tech for 20 years and my boss for 45
  • mincopier
    • Dec 2015
    • 289
    Re: ricoh Aficio MP C4502
    Without going the firmware route there is scan to FTP, Scan to Email and Scan to the Document server of the copier.
    • CopyBats
      • Aug 2011
      • 147
      ^^^^ All free and great options or you can purchase a NAS device. This way the scans are being placed in a central place, you can control access to users and its not taking up space on your pc.
      If it works, don't touch it.
        • 37533
        If you had specified your city and state we could recommend a competent dealer to contact to have it done correctly. If you try to do it yourself and crater the C4502, it comes out of your pocket. If a dealer tech makes a mistake, the dealer has to make it right.YouTube
          • 30300
          scan to ftp using fileszilla server is free and easy to setup if you don't get the firmware. Another option is to upgrade machine
            • 30300
            Nas drive will not work if its been update to block smb1
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Don't forget to search the forums relating to Filezilla as well.
              I uploaded a how to-set up guide a while back.
              • mincopier
                • Dec 2015
                • 289
                Quick and easy FTP works great also. Not as robust but gets the job done.
                  his answer is ALWAYS FTP...
                  problem is a lot of NA do NOT want FTP in their servers
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    true...I tend to use it for mom and pop businesses and even then as a last resort.
                    • printlessguy
                      • Sep 2015
                      • 63
                      well thanks for all the ideas. i got the firmware and am going there today. if all else fails I will try ftp. supposedly the scan to email was set up but it doesnt work either. there are times I wish I could bill like the old mechanics sign.
                      $75 an hr to fix....125 if you watch.......250 if you tried to fix it first. I think I am the third tech and company on this.......
                      • mikadonovan
                        • May 2008
                        • 2931
                        If the machines in question already have SMB v2/3 firmware loaded you might check a couple of things I have found recently. Two accounts that have scanning just stop had the same issues: Network discovery was turned off, and not by the customer, and sub folders of the scans folder had stopped their share (even though the scans folder indicated it was shared). Hope this helps someone.
                        NEVER ASSUME ANYTHING
